Compact database error
  • Compact database error
    I get this when I start HS3:
    10.06.2014 19:44:19 ~!~BLBackup Error~!~DatabaseFunctionsSingleton.CompactDatabase(): An error has occurred during compacting of the database:  Retrieving the COM class factory for component with CLSID {CD7791B9-43FD-42C5-AE42-8DD2811F0419} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
    DatabasePathAndName:  C:\Program Files (x86)\HomeSeer HS3\Data\BLBackup\BLBackup.mdb
    http://forums.homeseer.com/showthread.php?t=160399
    Cheers,
    Bob
      Excellent, thanks!
        I ran that data base fix and Now I get:
        Starting up....
        10/11/2014 4:54:02 PM ~!~BLBackup Error~!~DatabaseFunctionsSingleton.CompactDatabase(): An error has occurred during compacting of the database: Unable to cast COM object of type 'Microsoft.Office.Interop.Access.Dao.DBEngineClass' to interface type 'Microsoft.Office.Interop.Access.Dao._DBEngine'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{00000021-0000-0010-8000-00AA006D2EA4}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
        10/11/2014 4:54:02 PM ~!~BLBackup Error~!~DatabaseFunctionsSingleton.CompactDatabase(): DatabasePathAndName: C:\Program Files\HomeSeer HS3\Data\BLBackup\BLBackup.mdb
        Any Help?
          I have never seen this. A google search turned up this.
          Give it a look and see if it sounds like your issue
          http://stackoverflow.com/questions/1...com-components
          Cheers,
          Bob
            I had to install AccessDatabaseEngine.exe too. Backup works now. No errors in the log during backup. However, during HS3 startup, I also get the following startup error:
            Any word on when SQLite will be used in BLBackup?
            Thanks.
              Try this:
              Cheers,
              Bob
