new user, backup errors
  • new user, backup errors
    I am a new user to your program on HS3. I have been using the active backup program on HS2 for years but now I have migrated to HS3 and want a backup solution there. I have installed your plugin and set it up. However I get the following errors...Please advise on how to proceed. Thanks, Ricky
    Apr-28 11:41:03 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: ExecuteNonQuery requires an open and available Connection. The connection's current state is closed.
    Apr-28 11:41:03 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine.
    Apr-28 11:41:03 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\hspi_insteon.exe','4/28/2015 11:41:03 AM','4/28/2015 11:41:03 AM',1)
    Apr-28 11:41:03 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName: C:\Program Files\HomeSeer HS3\Data\BLBackup\BLBackup.mdb
    Apr-28 11:41:03 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\hspi_hstouch.exe','4/28/2015 11:41:03 AM','4/28/2015 11:41:03 AM',1)
    Apr-28 11:41:03 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\hspi_blbackup.exe.config','4/28/2015 11:41:03 AM','4/28/2015 11:41:03 AM',1)
    Apr-28 11:41:02 AM Web Server Web Server authorized login successful from: 150.135.210.95 User: ricky
    Apr-28 11:41:02 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\hspi_blbackup.exe','4/28/2015 11:41:02 AM','4/28/2015 11:41:02 AM',1)
    Apr-28 11:41:02 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName: C:\Program Files\HomeSeer HS3\Data\BLBackup\BLBackup.mdb
    Apr-28 11:41:02 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: ExecuteNonQuery requires an open and available Connection. The connection's current state is closed.
    Apr-28 11:41:02 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine.
    Apr-28 11:41:02 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\hscf.dll','4/28/2015 11:41:02 AM','4/28/2015 11:41:02 AM',1)
    Apr-28 11:41:01 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\hsaudio2.dll','4/28/2015 11:41:01 AM','4/28/2015 11:41:01 AM',1)
    Apr-28 11:41:01 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName: C:\Program Files\HomeSeer HS3\Data\BLBackup\BLBackup.mdb
    Apr-28 11:41:01 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: ExecuteNonQuery requires an open and available Connection. The connection's current state is closed.
    Apr-28 11:41:01 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine.
    Apr-28 11:41:01 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\hs3updater.ini','4/28/2015 11:41:01 AM','4/28/2015 11:41:01 AM',1)
    Apr-28 11:41:01 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\hs3updater.exe','4/28/2015 11:41:01 AM','4/28/2015 11:41:01 AM',1)
    Apr-28 11:41:01 AM Vista Alarm !EXP:12,01,00
    Apr-28 11:41:01 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\hs3sentry.exe','4/28/2015 11:41:01 AM','4/28/2015 11:41:01 AM',1)
    Apr-28 11:41:01 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\hs3.exe.manifest','4/28/2015 11:41:01 AM','4/28/2015 11:41:01 AM',1)
    Apr-28 11:41:01 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\hs3.exe.config','4/28/2015 11:41:01 AM','4/28/2015 11:41:01 AM',1)
    Apr-28 11:41:00 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\hs3.exe','4/28/2015 11:41:00 AM','4/28/2015 11:41:00 AM',1)
    Apr-28 11:41:00 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName: C:\Program Files\HomeSeer HS3\Data\BLBackup\BLBackup.mdb
    Apr-28 11:41:00 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: ExecuteNonQuery requires an open and available Connection. The connection's current state is closed.
    Apr-28 11:41:00 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine.
    Apr-28 11:41:00 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\homeseerapi.dll','4/28/2015 11:41:00 AM','4/28/2015 11:41:00 AM',1)
    Apr-28 11:40:59 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\ftd2xx_net.dll','4/28/2015 11:40:59 AM','4/28/2015 11:40:59 AM',1)
    Apr-28 11:40:59 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName: C:\Program Files\HomeSeer HS3\Data\BLBackup\BLBackup.mdb
    Apr-28 11:40:59 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: ExecuteNonQuery requires an open and available Connection. The connection's current state is closed.
    Apr-28 11:40:59 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine.
    Apr-28 11:40:59 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\export.txt','4/28/2015 11:40:59 AM','4/28/2015 11:40:59 AM',1)
    Apr-28 11:40:59 AM BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: INSERT INTO tblBackupFiles(txtBackupFile,txtLastFullBackupDate,txtLastUp dated,txtExists) VALUES('c:\program files\homeseer hs3\ettt35.ocx','4/28/2015 11:40:59 AM','4/28/2015 11:40:59 AM',1)
    Apr-28 11:40:59 AM BLBackup Error DatabaseFunctionsSingleton.GetADODBConnection(): Caught exception opening database connection: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine.
    Try this:
    http://forums.homeseer.com/showthread.php?t=160399
    Cheers,
    Bob
      Originally posted by Blade View Post
      Yep, that was it, thanks!
        Same issue and same fix here !
        Thanks for the back up plug-in and the answer to why it wouldn't work
