Linux support coming?
  • Linux support coming?
    I installed BLBackup on my HS3 linux VM and it installs just fine. I setup an event and when I kick it off nothing happens. I'm running HS3 has linux user "hs3" out of the /home/hs3 directory. My backup destination directory is a NFS mounted directory on /home/bkup/hs3 which is user/group owned by hs3 with 664 permissions.
    Is Linux supported? If so, any log files I can look at to see what is happening (or not happening)?
    It should work fine in Linux. I have it in Linux just fine.
    Check the [HS root]\bin\BLBlackup folder
    Tell me what is in that folder
    What DLLs exist in the hs3 root folder?
    Cheers,
    Bob
      I included the home and backup directory information so you can see the user/group and permissions information for the HS3 installation and backup destination.
      root@p-vubuhs301:/home/hs3/HomeSeer/bin/BLBackup# ls -l /home | grep hs3
      drwxr-xr-x 3 hs3 hs3 4096 Jan 17 11:22 hs3
      root@p-vubuhs301:/home/hs3/HomeSeer/bin/BLBackup# ls -l /home/bkup | grep hs3
      drw-rw-r-- 2 hs3 hs3 4096 Jul 5 16:11 hs3
      root@p-vubuhs301:/home/hs3/HomeSeer/bin/BLBackup# cat /etc/fstab | grep bkup
      192.168.1.18:/volume1/nastest /home/bkup nfs nouser,rsize=8192,wsize=8192,atime,auto,rw,dev,exec,suid 0 0
      total 1792
      -rw-r--r-- 1 root root 200704 May 25 2010 ICSharpCode.SharpZipLib.dll
      -rw-r--r-- 1 root root 677376 Nov 13 2012 sqlite3.dll
      -rw-r--r-- 1 root root 700928 Feb 14 2014 SQLite.Interop.dll
      -rw-r--r-- 1 root root 249856 May 21 19:12 System.Data.SQLite.dll
      And some screen shots of my BLBackup setup
        I just tried to run the backup again and am getting this message in the log... strange that I didn't get this message yesterday.
        Jul-06 11:00:51 AM BLBackup Warning You have not set a backup folder for the plug-in. Please specify the backup folder on the Options page!
        I changed the permissions to 777 for the /home/bkup and /home/bkup/hs3 directories just to make sure I didn't have an issue there... still not working. Does it matter that /home/bkup is a NFS mount?
        root@p-vubuhs301:/home# ls -l /home | grep bkup
        drwxrwxrwx 17 hs3 hs3 4096 Jul 6 01:19 bkup
        root@p-vubuhs301:/home# ls -l /home/bkup | grep hs3
        drwxrwxrwx 2 hs3 hs3 4096 Jul 5 16:11 hs3
        root@p-vubuhs301:/home# ls -l /home/bkup/hs3
        total 0
          You need to set a destination folder in the options page.
          Is one set?
          I ran another backup on my PI2 this weekend and it worked fine
          Cheers,
          Bob
            That was it - all fixed. I thought putting the "Destination Folder" in the "Backup Directories" configuration screen was where that was setup. Thanks for clarifying. All is good. Thanks!!
              You need a destination folder in the main options page
              If you put one in the event action it will use that otherwise it will use the one in the options
              Cheers,
              Bob
