Blade,
When I backup using a Zip file and the number of "backups to keep" selected is say 5, when you write a sixth you apparently erase the oldest Zip file so that the backup directory only ever contains 5 files.
When I switched to use uncompressed HS directories to the backup directory, you seem to erase individual files in the sixth backup but leave a bunch of empty folders for each of the older backups.
Is this by design? If so, can you add a feature to clear all remnants of the older backups?
BobSpen
BobSpen
