UNC / Mapped drive - won't work as destination folder :(
  • UNC / Mapped drive - won't work as destination folder :(
    Hello,
    I wanted to set the destination to a network path (raid drive)... but either as a mapped drive (Z:\) or the full UNC path, I can't the plugin to accept it. It throws an error "destination doesn't exist".
    But meanwhile, I have an explorer windows opened there without issue.
    Any work-arounds for this?
    thanks!
    Dave
    I'm having similar issues using either a mapped drive or a UNC path and my backup keeps failing. Could it be a permissions issue? What user does the plugin run as?
    Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
      Before migrating from Win7 to Win10 backup ran without problems. After the upgrade it I have the same isuues as described in the previous posts.
      Seems it may have to do with the permissions. What user is executing the HS-Plugin? Other than the user that is logged in to windows?
      In my setup I'm using a mapped network drive which is located on a linux-based NAS (QNAP). I'm on HS3.
        It is running as the user logged into the machine. Looks like something with permissions in windows 10.
        Cheers,
        Bob
          Known Win 10 bug. Check this out http://community.netapp.com/t5/Netwo...FS/td-p/108185 especially last post.
          Sent from my A0001 using Tapatalk
            In my case, it's Win 7 Pro.
            I turned off UAC and gave the HSPI_BLbackup.exe admin privledge.
            Although the mapped drive letter still doesn't work, I can use UNC.
            haven't had time to fully test, but it's an improvement.
              Tried that, and it made things worse: the network drive was not recognised at all, even not when addressed directly through the UNC path. I had to change back to the previous settings.
                FYI, tried a few backups, all seems ok for me. Although it might be a good addition to allow an option to the path for "log on as another user... "
                  Works for me too, thanks! A sufficient solution for the time being. Now got to work on Win10 to get all the permissions correct again.
