Failure: String was not recognized as a valid DateTime
  • Failure: String was not recognized as a valid DateTime
    When I start (manual or by an event) BLbackup I get the following failures:
    mrt-10 22:48:18 BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: String was not recognized as a valid DateTime.
    mrt-10 22:48:17 BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: String was not recognized as a valid DateTime.
    mrt-10 22:48:04 BLBackup Info The backup process (One Zip File - Differential) has started at 10-3-2016 22:48:04...
    It's the same message repeating during the backup. Any idea what's causing this? The backup seems ok. Even the log shows the backups:
    BLBackup_Backup_Log_2016-03-10_22-48-04_differential.htm 10-3-2016 22:48:04 562 bytes
    BLBackup_Backup_Log_2016-03-10_20-30-26_differential.htm 10-3-2016 20:30:26 1.752 bytes
    BLBackup_Backup_Log_2016-03-10_02-30-00_differential.htm 10-3-2016 2:30:00 1.748 bytes
    Version: 2.0.23.0
    Thanks!
    Are you using the latest BLBackup from the updater?
    Windows or linux?
    Cheers,
    Bob
      Hi Bob,
      Windows 7 Version BLbackup: 2.0.23.0
      Jos
        Bob,
        I've removed the plugin, deleted all files and installed it again. No solution:
        The error message increases every day:
        mrt-13 2:34:32 BLBackup Info The backup process (One Zip File - Full) has completed at 13-3-2016 2:34:32
        mrt-13 2:30:57 BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: String was not recognized as a valid DateTime.
        mrt-13 2:30:00 BLBackup Info The backup process (One Zip File - Full) has started at 13-3-2016 2:30:00...
        mrt-14 2:32:14 BLBackup Info The backup process (One Zip File - Differential) has completed at 14-3-2016 2:32:14
        mrt-14 2:30:21 BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: String was not recognized as a valid DateTime.
        mrt-14 2:30:00 BLBackup Info The backup process (One Zip File - Differential) has started at 14-3-2016 2:30:00...
        mrt-15 2:32:13 BLBackup Info The backup process (One Zip File - Differential) has completed at 15-3-2016 2:32:13
        mrt-15 2:30:21 BLBackup Error DatabaseFunctionsSingleton.PerformDatabaseMultiSelect(): Caught this Exception: String was not recognized as a valid DateTime.
        mrt-15 2:30:00 BLBackup Info The backup process (One Zip File - Differential) has started at 15-3-2016 2:30:00...
        Any ideas for a solution? Really like this plug-in.
        Jos
          I have a new build but not done testing it yet with a user.
          Once released it should help
          Cheers,
          Bob
            Thanks! Look forward to it.
              Try the new build in the updater
              Cheers,
              Bob
                I don't get the messages anymore. Seems to work ok.
                Thanks for the fast respons and solution.
                Jos
