A little help, please
  • Rotech
    Thanks Randy , I haven't been doing my back stradegy so I desided to start with this. The whole backup precedures is still in my to do list.
  • randy
    Originally posted by Rotech View Post
    Where can you find the help doc. I tried the help button but there nothing there?
    It is there on my system. The directory is "C:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLBackup" and the help file is "BLBackup_Help.asp".
    In my system there has been a real problem with many updates failing due to the file being in use. It has affected other authors plug-ins, not just Blades. The last few months, I have had to disable many plug-ins before they would update successfully. I wonder if one of yours failed and did not finish installing. Try disabling the plug-in, select it again then click Download and Install to install it again.
  • Rotech
  • donstephens
  • Blade
    The destination folder is where you want the backup stored
  • donstephens
    started a topic A little help, please
    This is probably obvious, but when trying to set up directories is the Destination folder where the backup is being sent to and the Directory the folder being backed up?
