Backup Failing to Mapped Driver after 2.0.27 Update
  • Backup Failing to Mapped Driver after 2.0.27 Update
    After applying update 2.0.27 my backups are failing with the log message that the backup directory was not accessible. This is the same mapped directory that worked before (I made no change to the configuration after the update) and I can access the mapped directory from Win 10 File Explorer. Below is the specific message with my Directory. Thanks
    ERROR: z:\mir\backups\hs3 backups was not accessible!!
    Blade I have the same issue. I think happened when I upgraded to Windows 10. I can see and select the directory under the mapped drive but your program gives me this error "The following validation error has occurred:Destination folder does not exist!
    Aldo
      I had the same, have you done similar? "//mappeddevice/Backups/"
      (using windows 10)
      I found changing it "\\mappeddevice\Backups" in both options worked for me.
      I really liked this plugin.
      Very handy, Thank you
