BLBackup Linux
    #16
    Originally posted by zwolfpack View Post
    Another, admittedly low-tech (but simple) solution is a USB flash drive. My BLBackup destination for my Hometroller S6 is this:
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Duh, I love this idea the best! Simple and easy as long as BLBackup allows me to choose a flash drive as backup location on the Raspberry Pi
    Your s6 or windows is easy for me. thats what I'm using now but trying to move to a linux or low power box.
    EDIT: All done, thanks for the obvious suggestion!
      #17
      Just google "raspberry pi mount usb drive".
      I have a couple of these, which work equivalent to a flash drive, but for a mini-SD card. I mount them all the time. If you run into problems just ask.
        #18
        I already responded"DONE". I already mounted a usb drive and setup the blbackup, and manually ran it and tested. Thanks again
          #19
          Originally posted by integlikewhoa View Post
          I'm currently also looking for a good solution to backup to a nas, windows machine or something else off the SD card of the pi. I'm afraid if the SD card takes a dive I don't want my backups to be on that same SD card.
          Anyone Come-up with a good solution?
          My advise would be to break your backups plans into three distinct components.
          First you need to backup and keep good pre-requisite notes on the OS. I use An RPI 3 as my Homeseer 3 server running Raspbian Jessie. I take a complete images of the flash at regular intervals using win32diskimager.
          Keep a backup of your install folder. In case you need to migrate to a totally different OS.
          http://board.homeseer.com/showthread.php?p=770449
          Lastly, take a backup of the config using the built in tool.
          Tools I use are BLBACKUP, samba and scripts to send files to my NAS.
            #20
            So complete SD card copy I think I understand
            The "install folder" I think you mean the "HomeSeer" main folder?
            And the built in backup of the config file, can that be done with an event and sent to a certain place?
            Also if your copying the whole sd card is it really needed to copy the install folder and or the config?
              #21
              You can never have too many backups!
              The sd card back up creates one big file, so the other backups are handy if you just need to recover one or a few files. However, I personally don't use the HS config backup feature as the other backups I use already backup those same files (plus more) daily.
              Cheers
              Al
                #22
                rpi-clone - alternative/supplement to Windiskimager
                Ran across this a few days ago - initial impression is good.
                https://raw.githubusercontent.com/bi...ster/rpi-clone
                Allows in-place clone of SD card. Another nice feature is that it allows down-sizing to a smaller SD card (as long as the used space fits of course).
                  #23
                  I hear you on that, but I do want keep it to a min. since my goal on a pi was to reduce everything. Storage on a pi is also some what limited (altho there are options)
                  Cheers
                  Al
                  Thanks for the info.
                    #24
                    The OS image ensures that you won't have to rebuild your server in the event of a failure, use it when making operating system changes to Linux.
                    Yes I mean the Homeseer folder. This allows you to backup software configurations separately from the OS. This can be done I between drive images for smaller changes
                    You could do with just doing an image only. I work in the IT field, sometimes being able to revert 1 file is preferable to the entire server.
                      #25
                      Hm. I guess I need to get a permanent mount from Zee2 to windows share, so I can use that as the backup destination. . .
                      Just implemented a script to upload via ftp.
                      Anyone found a quick guide for a permanent mount point from Zee?
                        #26
                        https://www.google.com/search?q=moun...utf-8&oe=utf-8
                        1st link looks promising.
                          #27
                          Thanks! Sometimes you ask before you look because you don't have time right at that moment. . .
                          I have done it before, but not in years. . .looks easy enough. That would be nicer than using FTP.
                            #28
                            Set it up. We'll see if it survives the next reboot.
