Old backups & logs not being purged
  • #31
    My updater is showing 2.0.40
    Can you clear your browser cache
    Try renaming the updater.txt
    Cheers,
    Bob
    • #32
      It took renaming the updater to .old, and then running it in a completely different browser (Waterfox instead of Opera). Even clearing the cache in opera didn't help for some reason.
      Install was successful. Thanks!
      One question to you: Is the proper method for restoring a backup to a total rebuild simply a copy of all the files back to their original location? I am running an SEL. Everything seems to be running OK after I did this but I want to make sure I didn't miss anything.
      • #33
        You should be able to just copy the backup into place and it should work fine
        Cheers,
        Bob
        • #34
          I note from above discussions that the deleting of old backup files and logs has been fixed. However, my setup does not seem to be deleting the old backup files.
          I have just recently started to use the plugin, so it may be that I am unfamiliar with the way the plugin works.
          I have run the plugin event 3 times so far. So now there are 3 backup files - see attached screenshot. But I have specified in the backup directory setting to keep only 1 backup. So theoretically it should have deleted at least one backup. Here is my log of the last event.
          Backup Log for 6/25/2017 9:28:26 AM
          ** Backup process (One Zip File - FULL) has STARTED at 6/25/2017 9:28:26 AM...
          Processing backup directory: /usr/local/HomeSeer ( Frequency: Weekly (Monday); Include Sub Dirs: Yes )
          Computer Name: HomeTrollerSEL; Unique Alias:
          Comment:
          Number of backups to keep: 1
          Zip File Path: /usr/local/HomeSeerBackup/HomeTrollerSEL/Weekly (Monday)/HomeSeer_WEEKLY-MONDAY_2017-06-25_09-28-27_FULL.zip
          4,151 files were processed
          0 files in use
          0 zip archive(s) deleted
          Backup time: 4 mins, 36 secs
          ** Backup process (One Zip File - FULL) has COMPLETED at 6/25/2017 9:33:03 AM
          ** Backup process took 4 mins, 36 secs to complete!
          Total backup directories processed: 1
          Total files processed: 4,151
          Total files backed up: 4,151
          Total files in use: 0
          Total old backup logs deleted: 0
          Total zip archives deleted: 0
          Attached are the relevant screenshots of my settings and event. Hope someone can advise.
          Current Date/Time: 6/25/2017 11:54:04 AM
          HomeSeer Version: HS3 Standard Edition 3.0.0.318
          Linux version: Linux hometrollerSEL 3.16.0-031600-generic #201408031935 SMP Sun Aug 3 23:56:17 UTC 2014 i686 i686 i686 GNU/Linux System Uptime: 2 Days 13 Hours 3 Minutes 52 Seconds
          IP Address: 192.168.100.101
          Number of Devices: 212
          Number of Events: 186
          Available Threads: 199
          Enabled Plug-Ins
          2.0.47.0: BLBackup
          2.0.35.0: BLLAN
          3.0.0.5: CM15A
          1.0.0.0: drhsEventEnabler
          3.0.0.103: HSTouch Server
          3.0.1.84: PHLocation
          3.0.4.8: SDJ-Health
          3.0.5917.35093: UltraLog3
          3.0.1.131: Z-Wave
