I do, and then, use the event to proc a pushover notification for status monitoring.
THanks. I see when creating an event it asks me for a destination folder. Assume i can leave blank as i have that setup through the plugin config?
Another question. How does "keep at most" work? I have mine set at 30. Does BLBackup just keep a count of 30, then overwrite the 31rst in the back directory i designated?
How can I use the device code for the status of the backup and send me a Pushover only if it fails? I couldn't find a device once I enabled this plugin.
HS3 3.0.0.548 &HSTouch Designer 3.0.71 with 996 Devices, 547 Events Plugin's:
