Problem uninstalling plugin
  • Problem uninstalling plugin
    I am trying to uninstall the plugin, it says plugin disconnected then nothing happens, its still there. In the log is this:
    Jan-31 13:19:28 BLCpuAdvisor start BLCpuAdvisor plugin has been initialized
    Jan-31 13:19:28 BLCpuAdvisor start Applications have been loaded.
    Jan-31 13:19:28 BLCpuAdvisor start Loaded configuration successfully
    Jan-31 13:19:28 BLCpuAdvisor start BLCpuAdvisor version is: 2.0.8.0
    Jan-31 13:19:28 BLCpuAdvisor start Initializing BLCpuAdvisor...
    Jan-31 13:19:28 Info Plugin BLCpuAdvisor has connected. IP:127.0.0.1:62938
    Jan-31 13:19:28 Warning I/O interface BLCpuAdvisor is down, executable is not running, restarting ...
    Jan-31 13:19:13 Warning Problem shutting down plugin Msg-B:BLCpuAdvisor
    Jan-31 13:19:13 Info Plugin BLCpuAdvisor with instance: has disconnected
    Jan-31 13:19:13 Warning Problem shutting down plugin Msg-A:BLCpuAdvisor:Object reference not set to an instance of an object.
