Give each directory a name in the directory panel
  • jimbell
    Success!
    v2.0.8 works great. Thanks again for the absolutely super response and update.
  • Blade
    Try 2.0.8
  • Blade
    Ah yes that will cause an issue
    I will need to make another change for that
    Will let u know when it is done - likely tomorrow
  • jimbell
    different problem
    I did the procedure and the installation went well.
    I get an error when adding the second directory.
    You have already selected this directory!
    I want the next directory is the same as the first, just a different file mask (and different name).
  • Blade
    Do this:
    1. Disable plugin
    2. Make sure the HSPI_BLEditor.exe is not running (if it is then kill it)
    3. Update the plugin
    4. Re-enable the plugin
  • jimbell
    Problem with update
    Blade,
    Thanks for the super quick update. However, there is a problem. When I attempt to update to 2.0.7 by checking the box, I get the following:
    Install/Update of package BLEditor failed.
    There is a red warning
    CRITICAL: Plugin has disconnected.
  • Blade
    Try out 2.0.7 in the updater
  • jimbell
    started a topic Give each directory a name in the directory panel
    I use your plugin to edit scripts on the Homeseer server from remote computers. Would it be possible to add a name to each directory that shows up instead of the full directory name in the view panel.
    In my particular case, I would like to define the following 2 directories in the directory panel.
    c:\Program Files\Homeseer HS3\scripts with a file mask of *.vb. It's name would be "VB scripts".
    c:\Program Files\Homeseer HS3\scripts with a file mask of *.vbs. It's name would be "VBS scripts".
    When I go to the view panel and click on the dropdown, I would see "VB Scripts" and "VBS Scripts".
    Being able to use a defined name instead of the full directory name would be a very nice feature for this very fine plugin.
    Any thoughts?
