No calendars
  • No calendars
    I have created the Google API as best as I can and have the key and secret id. I don't know if they are right or not, but I do get a display under the API dashboard that does list calendar, task and contact APIs. no requests or errors or other traffic is listed for these APIs. I enabled the plugin's debug log and notice a message therein that claims I have no calendars. That not true so I can only assume I have some type of login problem with either my Gmail account of the client id / secret stuff. I did what I know to do and all of the numbers and passwords, etc are right - as far as I can tell. Any suggestions?
    -Rick
    Did you enable the calendar API in the Google console
    There is a spot where you can enable the APIs you want to use
    Cheers,
    Bob
      Under the Google Dashboard, it displays the 3 (contact, calendar, and tasks) APIs and affirmatively displays enabled for each one.
      -Rick
      -Rick
        OK then do the following:
        Log a ticket on my help desk.
        1. Disable the plugin
        2. Edit hspi_BLGData.ini and change debugLevel=true and save INI file
        3. Re-enable plugin
        Access the calendar page for a user in the plugin and capture the issue
        Turn off debug logging and attach the BLGData-Detailed.log file zipped to the ticket
        It is in the HS3 root folder
        Cheers,
        Bob
