Bug report: "Use End Time" not working
  • Bug report: "Use End Time" not working
    @Blade
    Hi, I just bought HS3 and am testing BLGData as i prepare to migrate from Vera.
    It seems i ran into a bug: The "Use End Time" check box on the Handler screen is not being saved or used.
    a) The handler still runs at the start of the Google calendar event regardless of whether I checked the "Use End Time" check box or not when I setup the hander (in the HS3 log i can see the HS3 Event being run at the start of the google calendar Event time rather than at the end), and
    b) when I return to the hander to edit it the check box does not display on the screen at all. Perhaps it is not being saved?
    Please let me know if there is anything I can do to help track this down. Thanks!
    I do not see any errors in the log (Debug Logging is enabled in the plugin):
    May-21 3:53:51 PM	 	BLGData start	BLGData plug-in has been initialized
    May-21 3:53:50 PM	 	BLGData start	No notifications have been assigned to BLGData!
    May-21 3:53:50 PM	 	BLGData start	Handlers have been loaded.
    May-21 3:53:50 PM	 	BLGData start	Users have been loaded.
    May-21 3:53:50 PM	 	BLGData start	BLGData Debug Logging is Enabled!
    May-21 3:53:50 PM	 	BLGData start	Loaded configuration successfully
    May-21 3:53:50 PM	 	BLGData start	BLGData version is: 2.0.33.0
    System info:
    Current Date/Time: 5/21/2017 4:09:20 PM
    HomeSeer Version: HS3 Pro Edition 3.0.0.318
    Operating System: Microsoft Windows 7 Enterprise - Work Station
    System Uptime: 0 Days 0 Hours 58 Minutes 5 Seconds
    IP Address: 192.168.1.141
    Number of Devices: 144
    Number of Events: 8
    Available Threads: 200
    Enabled Plug-Ins
    3.0.0.14: Autelis
    2.0.33.0: BLGData
    2.0.35.0: BLLAN
    3.0.0.16: Ecobee
    5.0.0.58: Global Cache Pro
    3.6.5.0: Harmony Hub
    3.0.0.68: HSTouch Server
    1.0.17123.357: MyQ
    3.0.0.21: Sonos
    3.0.0.63: weatherXML
    3.0.1.87: Z-Wave
    -Michael
    Solved
    Thanks for your help @Blade... this was user (me) error. The Plug-in is working fine.
    For any others who run into this, the solution is to put a number into the "Number of minutes after" field and then check the "Use End Time Check box".
