Does anyone have this feature up and running? Been waiting almost 7 months for a fix and seeing if anyone still has it or has gotten it to work.
BLGData SMS
You can try the newest build in the updater
You will need to do the following:
1. Disable the plugin
2. If the HSPI_BLGData.exe is still running then kill it
3. Update the plugin
4. Re-enable the plugin
I cannot test google voice here in Canada as it is not available to us so you will have to try it. There is not an official API for google voice.
I am glad to report that BLGData SMS is working. I took some time this evening to remove all and start from scratch and set up.
It is working quite well with latest version from the updater.
Question, is it possible to use HS3 replacement variables in the SMS message? I am trying to report device values via SMS but not successful.
Will
Still works for me. I received an SMS less than 30 mins ago.
Not sure what I did to get it to work. Honestly, I don't think it had anything to do with uninstalling and re-installing the plug in. I am leaning more towards the issue was with my google API project.
I noticed after I created a new project and followed Blade's directions to create an OAuth 2.0 client ID and secret word, it came right up and worked the first time.
I added my second google account and it works as well.
I hope this helps you troubleshoot...
Originally posted by will40 View PostStill works for me. I received an SMS less than 30 mins ago.
Sent from my XT1585 using Tapatalk
The directions for the API are old, are there new ones that I am missing/.
Originally posted by cpd5899 View PostThe directions for the API are old, are there new ones that I am missing/.
I believe 'Overview' from the docs is now 'Dashboard' in Google API. All else was easy enough to navigate and figure out from the docs.
Are you able to provide screen shots of your steps? I've tried it MULTIPLE times with no success
Originally posted by will40 View PostI used the doc from this post: https://forums.homeseer.com/showthread.php?t=179686
FINALLY working
So, I had to follow the steps as directed, and thanks for the tip about the change.... BUT.... I had to completely uninstall AND delete all of the BLGData files, and then reinstall and setup everything again.
I finally get my msgs within seconds as opposed to sending myself an email SMS.
