I setup everything according the provided doc.
Got the 3 API's running
Made a user with the client-id and secret key.
I enable all 5 options with the user.
But in the overview screen only calendar and voice show.
When clicking calendar nothing shows (only add new option), with debug option on in the settings. noting appears in the homeseer log.
When clicking on voice and try the option send sms.
I do get a google notification about a login attempt to my account but no sms is received. (im not going to use the option but i tested it), try to send a second sms after approving the login attempt. The second sms also didn't come in.
Homeseer log isnt showing any errors, actually it only showed that the plugin is started and users are loaded:
======start log============
aug-19 11:42:14 BLGData start BLGData plug-in has been initialized
aug-19 11:42:14 BLGData start No notifications have been assigned to BLGData!
aug-19 11:42:14 BLGData start No handlers have been assigned to BLGData!
aug-19 11:42:14 BLGData start Users have been loaded.
aug-19 11:42:14 Info Running immediate script: C:\Program Files (x86)\HomeSeer HS3\Temp\K1.vb
aug-19 11:42:13 BLGData start BLGData Debug Logging is Enabled!
aug-19 11:42:13 BLGData start Loaded configuration successfully
aug-19 11:42:13 BLGData start BLGData version is: 2.0.40.0
aug-19 11:42:13 BLGData start Initializing BLGData...
aug-19 11:42:13 Info Plugin BLGData has connected. IP:127.0.0.1:56781
=========end of log==================
In the dashboard overview of the google api; traffic, errors and wait time are all 0.
Tried restarting homeseer and even removing and reinstall plugin but all have the same result. Im still in trail periode but i dont think that's the problem
in the detailed log in the homeseer root directory i see the following:
===============log==============
19-8-2017 12:04:28 : v2.0.40.0 - Check_Calendar_Events(): usr.ToString -->
User:
Key: U20170819T113842246
EmailAddress: kxxxxxx@gmail.com
EnableCalendar: True
EnableContacts: True
EnableTasks: True
EnableVoice: True
EnableGooglePlus: True
Calendar Count: 0
Contact Count: 0
Contact Group Count: 0
ProcessedEvents: 0
ProcessedEventOffsets: 0
ProcessedReminders: 0
19-8-2017 12:04:28 : v2.0.40.0 - Check_Calendar_Events(): *** user has 0 calendar(s)!!!
19-8-2017 12:04:28 : v2.0.40.0 - Check_Calendar_Events() finished
19-8-2017 12:04:29 : v2.0.40.0 - HSEvent() started
19-8-2017 12:04:29 : v2.0.40.0 - DeviceReceivedQueueSingleton.AddDeviceReceivedToQueue() started
19-8-2017 12:04:29 : v2.0.40.0 - DeviceReceivedQueueSingleton.AddDeviceReceivedToQueue(): theDeviceReceivedData.ToString -->
DeviceReceivedData:
============end log===============
i editted the key number but its strange i says 0 calendars when i have 2... and also when api monitor isn't seeing any connection.
User:
EnableTasks: True
EnableVoice: True
Calendar Count: 0
Contact Count: 0
ProcessedEvents: 0
DeviceReceivedData:
