can I extract calendar entries
  • can I extract calendar entries
    Can I extract calendar entries with this plugin to display them in a virtual device ? I want to display lets say the next 3 entries in a virtual device. Or if that's not possible maybe for the week or month
    I believe there is a scripting call to return events but as I am not home right now I will have to look that up once I get home.
    Check out the help web page in the plugin. The call should be listed there
    Cheers,
    Bob
      Ok i founve found a starting point
      Dim allEvents As Object()
      allEvents = hs.PluginFunction("BLGData", "", "GetCalendarEvents", new Object(){"me@here.com","My Calendar","08/21/2013"})
      For Each ev As Object In allEvents
      hs.writelog("Info", "Event Name: " & ev.Name)
      Next
      that writes the number of days I specify into the log. What I get is just the event name, but not the date or start time. Can I get that information too ?
        See the Calendar Event Properties in the help web page
        Cheers,
        Bob
          Ok lets say I want the event name and start date. I have tried this but I get this error:
          Sub Main(parm as object)
          allEvents = hs.PluginFunction("BLGData", "", "GetCalendarEventsForXDays", new Object(){"xxx@gmail.com","xxx@gmail.com",14})
          hs.writelog("Info", "Event Name: " & ev.Name, "Event start date: " & ev.StartDate)
          Next
          End Sub
          Oct-03 22:35:43 Error 1 Running script C:\Program Files (x86)\HomeSeer HS3\scripts\BLGdata
          test.vb :Exception has been thrown by the target of an invocation.Overload resolution failed because no accessible 'writelog' accepts this number of arguments.
          Ultimately I want the data not being written to the log but to variables or as a string to a device but the log is good enough for testing at the moment, thats the next step once I know how to extract the data
            Try this:
                    hs.writelog("Info", "Event Name: " & ev.Name & "; Event start date: " & ev.StartDate)
                Next
            End Sub
            Cheers,
            Bob
              I think you write log should be:
              hs.writelog("Info", "Event Name: " & ev.Name &", Event start date: " & ev.StartDate)
              Greig.
              Sent from my SM-G950F using Tapatalk
              Scripts =
              Various
                Ok I got that working. Now, can I retrieve just the next 3 events, rather than by days ?
                  I have everything working, a daily email with the next 14 dyas events, and also a virtual device displaying my upcoming events. Great. One thing I cannot get to work though. I get all the google calendar events, but not the birthdays. I would like to include birthdays in my emails and the event display. If I go into google calender (web not via the PI) if I tick contacts they show up. If I go into the PI, click on calendar, then contacts, the page loads as the calendar one, but is blank. In edit calendar I have ticked everything, calendar, contacts, taks etc
                  If I look at the BLGData - Maintain Users page, I can see my name, with calendars and voice under it. But no contacts, tasks ot google plus. I have disabled them all, saved, then there is nothing, then ticked them all and saved again. I still only have calendars and voice.
