Calendar event retrieval stopped working
  • Calendar event retrieval stopped working
    I use a script to retrieve my calendar events. It has worked fine now for a few days. I have not changed anything, but today noticed it has stopped working, and a few minutes after running the script I see these errors in the log:
    Oct-09 13:39:15 Error Calling HSEvent in plugin BLGData, Instance :Object reference not set to an instance of an object.
    Oct-09 13:39:14 Error 1 Running script C:\Program Files (x86)\HomeSeer HS3\scripts\SendCalEvents.vb :Exception has been thrown by the target of an invocation.Object reference not set to an instance of an object.
    Ok I know what the problem is. Every time I log onto my HS3 machine, I get a pop up do you want HS3 to be able to access your calendar. I clicked allow about 6 times, then all was working again. There must be a way of permanently allowing it, rather than having to click allow every time ?
    Unconfigured PHP Module
