Why do I have to keep confirm access to my google calendar
  • Why do I have to keep confirm access to my google calendar
    I have given my HS3 access to my google calendar, everything works. But every time my system restarts, on my HS3 PC a message comes up, first Google choose an account. I select my account (email), then it wants me to confirm HS3 wants to manage your calendars. I always click alow, and all is good again. The problem is, I rarely look at my HS3 PC, I can only access it remotely as it does not have a permanent screen attached. And if I do not accept these promts, my calendar events do not work.
    I have checked in my google account, and I can see HS3 has permission to access and manage my calendars. I cannot see any setting in google on this permission, it looks as if its permanent, but why does this keep coming up on every restart ?
    That is odd - I just restarted mine and the page did not pop up for me
    What google URL are you using for your oauth credentials
    Cheers,
    Bob
      not sure what you mean by which google url oauth
        I use this site to see my oAuth key
        https://console.cloud.google.com/
        Under APIs and Services, you should see Credentials
        This is where my OAuth 2.0 client IDs are listed
        Cheers,
        Bob
          Ok thats different to what I use:
          https://console.developers.google.com/apis/
          actually when I use your link and click on api and services I land on the same page with my api and secret keys
            It looks like the same location
            Show the url where you show that pictures from your first thread
            Cheers,
            Bob
              https://myaccount.google.com/permissions
                I have removed my access and will play around with it here
                Cheers,
                Bob
                  I just tested it again, turned off the plugin, turned it back on and immediately the popup comes up, google choose account... as per my first post
                    I restarted BLGData here and it popped up the web page. I clicked Allow and it seems to be fine here
                    I restarted again and it did not pop up here
                    Cheers,
                    Bob
                      Here is my page
                      Cheers,
                      Bob
                        I have been playing with this a little bit now. And the page does not come up any more. It did once, but not again. Strange as this has been happening since I've started testing this plugin, I just never got around to posting about this. Not sure if the problem is solved permanently now, even after a restart it did not come up and everything is working.
                        Fingers crossed and it'll stay thay way... If not I'll be adding to this thread again but I am away for a few days now and cannot test anything.
                          OK the problem has come back. I had quite a few restarts trying to exclude a non functioning node, had a look on my HS3 pc and there it is again... google choose an account...
                            Is there any way to circumvent this having to confirm access to the calendar every time I reboot HS3 ? Its very annoying as it stops BLGdata related events from working. And unless I am in the house I cannot log into my HS3 PC to click allow... if I could automate that somehow out of windows that would do me as a temporary measure.
                            Apart from that the plugin is perfect for my purposes.
                              I cannot duplicate this here. I have removed my access many times and it seems to always stay once I approve it.
                              I just restarted HS3 this morning and there were no popups
                              Do you see any errors at all?
                              Cheers,
                              Bob
