Does the test button next to the handler fire the command stack on that handler, ignoring the actual Event criteria requirements itself? I checked the docs and it wasn't explained.
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
