Can't get it to work ... again.
  • Can't get it to work ... again.
    So, I'm not getting an popup for reauthenticating the API, no matter which browser I try.
    I have popups allowed, and I click the 'reauth' button in your plugin.
    I have also tried readding the user as well (google apps).
    The plugin just spins, when clicking on the users calendar or other items.
    Look in the following folder:
    [HS3 root]\Data\BLGData
    You should see a folder with BLGData-[user]
    Go into that folder and delete the files in there
    Then restart the plugin
    I just did that here and it prompted me for the approval again
    I will have to take a look at the Reauth button on the options page
    Cheers,
    Bob
      That didn't work for me. I then disabled the plugin and deleted the plugin, made sure no residual traces were left, reinstalled the plugin, added my user, and I still have no popup auth box?
      No errors in the debug log either....
        Well that is odd - I just did it a few more times here and got prompted every time
        The pop up will only show on your HS3 machine because that is where the plugin is running
        Install 3.0.6 I just put in the updater - I fixed the Reauth button on the options page
        I ran the reauth button a few times and it reset things and prompted me the next time I went into the calendar
        If it does not work then capture me a debug log of it
        Cheers,
        Bob
          I didn't realize I needed to run HS3 web gui from the same server it runs on...that is probably most of the reauth issue.
            Yea I tried to get it to pop up on the machine you were on but it insists on popping up on the HS3 machine
            Cheers,
            Bob
              Nope none of your suggestions worked.
              The plugin just recreated the auth file as soon as I restart the plugin...it never pops up and asks for auth permissions from google?
                I am at a loss as you are the only one reporting this.
                How many files are in the BLGData-[user] folder
                Capture me a debug log so I can see what is happening
                Do a reauth first and then access the calendar
                Cheers,
                Bob
                  Their was 1 file.
                  I just stopped the plugin, deleted the plugin, deleted ANY BLGData from the HS3 folder / sub-folders, reinstalled, started the plugin, added a user (me), and it still didn't ask me to authorize.
                    I just tried the re-auth in Chrome and IE with no popup?
                      I just emailed you the latest debug log.
                        OK, it's working now.
                        It was all because I run HS3 using AlwaysUp.
                        I shutdown the service, started HS3 from the Windows shortcut, and it immediately asked me for Google Authentication.
                        I tested the plugin and it was working great.
                        Thank you for checking into my issue.
                        Too bad running HS3 as a service has so many little quirks.
                        Unconfigured PHP Module
