Multiple Trigger Phrase in one Handler?
    Is it possible to use multiple Trigger phrases in one Handler? For example I would like to use the same Handler for events with the word "work" and "school" I could enter the words separated by comma? Or is this only possible by using scripting?
    Right now this will not work
    You can add a feature request on my site
    Cheers,
    Bob
      Thx 4 your reply. I'm currently testing Blgdata (demo) so will have to purchase a license first.
        I have added the change to 3.0.10
        See the beta section for the new version
        You can separate multiple trigger phrases in a handler by using a pipe (|) character
        Cheers,
        Bob
          Amazing @Blade ... I will test this tmrow & rvrt outcome.
            The new feature with separating multiple phrase triggers works as advertised, however the "Offset before" setting does not work together with this. The handler is triggered on Event start instead of x amount of minutes before. Also (I know this is probably asking too much), it would be really nice to make it possible to filter on which calendars to search from. Maybe make a new field and separate the calendar Id's to search in separated by the pipe sign?
              I will take a look at the offset before.
              Can you be more specific exactly where you would want to see a filter for the calendars
              Maybe a screenshot
              Cheers,
              Bob
                Filtering by calendar would be great. For example, I used to have a handler for "Work" which would do some stuff when I had work that day. Well, now that my daughter has a job and she puts her work schedule in a shared calendar I get woken up at 4:30 in the morning on Saturday when she works on Saturday evening.
                Originally posted by rprade
                  Great
                  Can you be more specific exactly where you would want to see a filter for the calendars Maybe a screenshot
                  Here you go Blade. I have added info on how and where I would like to see this feature in the attached screenshot
                    OK I see what you want now
                    Can I get you to put in a feature request on my web site for this so I can track it
                    Just put in a reference to this thread in the feature request
                    Cheers,
                    Bob
                      Done - added request # 607
                        Can you capture a debug log in the plugin of the before offset issue
                        Attach the BLGData-Detailed.log zipped
                        Also attach your hspi_BLGData.ini file zipped
                        Cheers,
                        Bob
                          Try out the handlers in 3.0.11 in the beta section
                          I have not completely tested but I thought I would put it out there for you to try out
                          Let me know
                          Cheers,
                          Bob
                            I have captured a debug log in the plugin of the before offset issue and attached the BLGData-Detailed.log and hspi_BLGData.ini file. Password for opening the zip file has been sent to you in a PM
                            I tested version 3.0.11 and there is no difference. The handler is triggered only on Event START time and not 5 minutes before or after as configured in the handler. Also I tested the new filter function and it only works if you specify the calendar. In other words: the handler will not trigger if you do not specify the calendar in this version of BLGData
                              OK I will take a look and let you know
                              Cheers,
                              Bob
