HS3 Crashing
  • HS3 Crashing
    I'd like to return to version 3.0.20.0 of the plug-in, as HS3 started crashing after I upgraded.
    I disabled handlers, so they are not the cause of the crash.
    Blade, could you please let me know how to return to the previous version?
    Thanks!
    What version of HS3 are you using?
    Mine was crashing on .425 and .426 so I went back to .423 and it has been fine since
    You could try and leave BLGData disabled and see if HS3 crashes
    Cheers,
    Bob
      I am using the latest published version 3.0.22.0.
      When disabled, HS3 does not crash, so I'm pretty sure it's the plug-in.
      I'm using HS3 Pro Edition 3.0.0.425 (Windows).
        Also, I'd like to try to downgrade HS3, but I cannot find the old versions for download...
        There were lots of people crashing with .425, I imagine many without this plugin. Try upgrading to .434
        cheeryfool
          Where did you find that version? .435 is the most recent that seems to be available.
            435 is probably better then. You can usually modify the URL of a link you have to find the later ones
            cheeryfool
              I installed HS3 Pro Edition 3.0.0.435 (Windows), and it's no longer crashing. HS3 was the culprit.
                Good stuff!
                cheeryfool
