BLGData - INFO: Plugin start is pending
  • BLGData - INFO: Plugin start is pending
    Hi All,
    Actually purchased this Plugin 4 years ago and have never really used it. I now have a Samsung galaxy phone so thought I might try and set up the calendar and use the Plugin for reminders to aid my struggling memory.
    Have been just updating the Plugin as new versions came along, some where along the way it has stopped working. I have not attempted to fix it and am posting here only to see if some one else has had the same issue and knows how to fix it.
    Peter
    HomeSeer Version: HS3 Pro Edition 3.0.0.435
    Operating System: Microsoft Windows 7 Home Premium - Work Station
    System Uptime: 7 Days 12 Hours 40 Minutes 35 Seconds
    Number of Devices: 474
    Number of Events: 187
    Enabled Plug-Ins
    3.3.0.0: APCUPSD
    1.0.0.147: Arduino Plugin
    2.0.59.0: BLBackup
    3.0.27.0: BLGData
    2.0.24.0: BLUPS
    3.0.0.50: EasyTrigger
    0.0.0.42: Pushover 3P
    30.0.0.36: RFXCOM
    2.6.2.0: SCSIP
    3.0.6629.22233: Ultra1Wire3
    3.0.6644.26753: UltraLog3
    3.0.0.36: X10
    3.0.1.239: Z-Wave
    Bump - Anybody?
      Maybe restart the plugin. Or maybe there’s is a new authentification process after all theses years?
      I would start from scratch. Delete all the file associated to the plugin in you has3 folder , and reinstall the plugin again? Maybe you will get a windows firewall popup?
        Can u install the latest from the beta section
        Delete the folder called "BLGData-yourname" under the [hs3 root]\Data\BLGData
        Then restart the plugin
        Once you try and access the calendars you will get a popup browser window on your HS3 machine
        You need to accept it
        You also need to make sure your calendars are public
        Cheers,
        Bob
          Hi Both,
          Thanks for taking the time to reply.
          So, Not sure if this is a senior moment, as per Bob's instructions downloaded the beta 3.0.29.0.
          The went to "Delete the folder called "BLGData-yourname" under the [hs3 root]\Data\BLGData"
          This does not exist and I must admit I never recall seeing a folder "BLGData-myname"
          Reloaded 3.0.27.0 - Still no folder in Homeseer HS3/Data/ "BLGData-anything"
          Reloaded 3.0.29.0 - Still no folder in Homeseer HS3/Data/ "BLGData-anything"
          Updater log
          Oct-27 15:59:49 Updater Install/Update of package BLGData was successful.
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\HSPI_BLGData.exe.config
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\HSPI_BLGData.exe
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Zlib.Portable.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\System.Threading.Tasks.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\System.Runtime.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\System.Net.Http.WebRequest.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\System.Net.Http.Primitives.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\System.Net.Http.Extensions.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\System.Net.Http.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Microsoft.Threading.Tasks.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.Apis.Tasks.v1.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.Apis.Samples.Helper.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.Apis.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.Apis.Authentication.OAuth2.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.Apis.Auth.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\DotNetOpenAuth.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Zlib.Portable.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\System.Threading.Tasks.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\System.Runtime.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\System.Net.Http.WebRequest.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\System.Net.Http.Primitives.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\System.Net.Http.Extensions.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\System.Net.Http.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Microsoft.Threading.Tasks.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.Apis.Tasks.v1.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.Apis.Samples.Helper.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.Apis.Auth.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.Apis.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.Apis.Authentication.OAuth2.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.Apis.Auth.PlatformServices.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.Apis.Auth.PlatformServices.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.Apis.Calendar.v3.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.Apis.Calendar.v3.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.Apis.Core.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.Apis.Core.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\DotNetOpenAuth.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.Apis.PlatformServices.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.Apis.PlatformServices.dll
          Oct-27 15:59:49 Updater Warning File exists, not overwriting: D:\Program Files (x86)\HomeSeer HS3\html\bin\Newtonsoft.Json.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\SharpVoice.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.Apis.Plus.v1.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.GData.Extensions.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.GData.Client.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.GData.Contacts.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.GData.Calendar.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.GData.AccessControl.DLL
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\GoogleChartSharp.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\GoogleChartSharp.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Newtonsoft.Json.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Microsoft.Threading.Tasks.Extensions.Desktop.dl l
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Microsoft.Threading.Tasks.Extensions.Desktop .dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Microsoft.Threading.Tasks.Extensions.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Microsoft.Threading.Tasks.Extensions.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\SharpVoice.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\log4net.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\log4net.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\System.Data.SQLite.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\System.Data.SQLite.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Newtonsoft.Json.Net35.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\HtmlAgilityPack.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\HtmlAgilityPack.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\Google.Voice.Service.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.Voice.Service.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.Apis.Plus.v1.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.GData.Extensions.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.GData.Client.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.GData.Contacts.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.GData.Calendar.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\bin\BLGData\Google.GData.AccessControl.DLL
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\AjaxMin.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\bin\AjaxControlToolkit.dll
          Oct-27 15:59:49 Updater Warning File exists, not overwriting: D:\Program Files (x86)\HomeSeer HS3\html\bin\Anthem.dll
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\BLGData\web.config
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\BLGData\BLGData_gplus.aspx.vb
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\BLGData\BLGData_tasks.aspx.vb
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\BLGData\BLGData_voice.aspx.vb
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\BLGData\BLGData_contacts.aspx.vb
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\BLGData\BLGData_calendar.aspx.vb
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\Docs\BLGData-Google API Setup Guide.docx
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\Images\BLGData\unknown.jpg
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\Images\BLGData\calendar.gif
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLGData\Images\maintainHandlersPage.jpg
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLGData\Images\optionsPage.jpg
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLGData\Images\webInterface.jpg
          Oct-27 15:59:49 Updater Copying file: D:\Program Files (x86)\HomeSeer HS3\html\BLHelp\BLGData\BLGData_Help.asp
          Oct-27 15:59:47 Updater Installing package BLGData
          Oct-27 15:59:47 Updater Update hspi_blgdata.exe downloaded successfully
          Oct-27 15:59:45 Updater Downloading update: BLGData
          Oct-27 15:59:45 Updater Starting download of updates
          Hope this helps
          Peter
            Have you added a user to the plugin?
            If so go the the calendars for the user - do you see the calendars?
            Cheers,
            Bob
              Hi Bob,
              "Have you added a user to the plugin?
              If so go the the calendars for the user - do you see the calendars?"
              Years ago I was able to see a calendar, now can not see a calendar also don't know how to add a calendar and no links to anything from the Plugin, was looking for the "Help"
              to try and set up the Plugin from scratch.
              I do have an API key and secret and have just made my calendar public.
              I did when I set this up originally struggle, basically don't understand API etc so somewhat of a mystery to me. Guess I got it working more by luck than judgement originally.
              As for ""Have you added a user to the plugin?" Totally lost here. Would you be kind enough to point me in small steps.
              Sorry to be a pain. Really would like to get this working as I can hopefully use it to get my house phone system to speak reminders.
              Patients appreciated .
              Peter
              Edit
              Found where the help files is but can't open it, no link from the Plugin.
                Go to the plugin web page and click on Users
                You need to add your user google account there and enter your client id and secret key
                Under google services - make sure to select at least Calendar for now
                You should then see your user added to the users page
                Click on the Calendars link under your user name
                That should list all of your google calendars - this will popup a internet window on your HS3 machine for you to authorize the api
                if it does not then there is an issue
                Let me know if you have the user added and the outcome
                Cheers,
                Bob
                  Hi Bob,
                  Only option I have is to either enable or disable the plugin from the manage page. No links from the plugin at all.
                  Post #1 shows the plugin as it appears in the manage page.
                  Peter
                    So the plugin is not starting for you?
                    If so, then do this for me
                    Make sure you have done this first
                    https://forums.homeseer.com/forum/3r...gging?t=196104
                    1. Shutdown HS3
                    2. Edit hspi_BLGData.ini in the config folder and change debugLevel=true
                    3. Save INI file
                    4. Restart HS3
                    Once started go to the options page in the plugin and disable debug logging if you can
                    If not then just attach the BLGData-Detailed.log file zipped
                    It is in the HS3 root folder
                    Cheers,
                    Bob
                      Hi Blade,
                      Set hspi_BLGData.ini debugLevel=true and restarted HS
                      No log found in root.
                      Peter
                        Is the plugin enabled?
                        If the plugin is enabled then there should be a log
                        Can you make sure you are running the version of the plugin in the beta section of the HS3 updater
                        Cheers,
                        Bob
                          Really do hope I am not having a senior moment.
                          The plugin is enabled and on version 3.0.29.0.
                          Have attached views just in case.
                            I do not like the "INFO: Plugin start is pending" message
                            I am not sure why that is showing
                            Does that always show? That could be why it is not running but I am not sure why that is
                            There should be a BLGData-Detailed.log file in the HS3 root folder if the plugin has even started to initialize.
                            This is very odd
                            Post a screenshot of your hspi_BLGData.ini file - be sure to blackout your google information
                            Cheers,
                            Bob
                              Hi Bob,
                              Yes the message "INFO: Plugin start is pending" always shows or at least it has done for sometime, I cannot recall when it started. The Plugin did work way back in 2014.
