Scripting methods returning events cause "Dropping event callbacks" log entries
    Every time I call a script method that returns events (like GetCalendarEventsForXDays), I get this message in the log, and nothing else happens.,.
    The message:
    Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates.
    I also get Type: 1024.
    I deactivated all but one of my calendars, disabled handlers, but get the same result.
    This has been happening for quite a while (several weeks, if not months), but I didn't have the time to take a closer look until now.
    What has changed?
    Thanks for looking into this!
    I am not sure that message has anything to do with the plugin
    The GetCalendarEventsForXDays script call does not send any event callbacks
    What version of HS3?
    Cheers,
    Bob
      I'm using HS3 Pro Edition 3.0.0.435 (Windows). I'm pretty sure that it's this plugin. I almost never get these log entries, but after every call (I have about 8 calendars, which I check periodically), I consistently receive the message, once for every calendar.
        Do you have HSTouch running?
        I am curious if it still happens if you disable that temporarily
        Cheers,
        Bob
          It doesn't change the behaviour.
            OK capture me a debug log of you running that script command
            That message is not coming from my plugin
            I will see if the log shows any errors
            Cheers,
            Bob
              Here is the debug log and the hs log - you'll see in the hs log that as soon as I turn on debugging, I start receiving the messages as well.
                You need to run this first to fix your debug log values
                https://forums.homeseer.com/forum/3r...-debug-logging
                After that then delete the debug log and capture it again and attach zipped
                Cheers,
                Bob
                  When I ran it this time, I found this in the log:
                  Nov-09 8:54:31 PM Warning Plugin BLGData is not responding but it is still running, not restarting yet.
                  Nov-09 8:54:24 PM Warning Dropping event callbacks due to full queue (Type: 64) (500 entries), system may be too busy, plugins and HSTouch may not receive all device updates
                  Nov-09 8:54:23 PM Error Calling HSEvent in plugin BLGData, Instance :Object reference not set to an instance of an object.
                  Nov-09 8:54:23 PM Calendar Exception Unable to cast object of type 'System.String' to type 'System.Object[]'.
                  I e-mailed you the zip file, it was too big to attach.
