Google+ APIs and OAuth requests are being shutdown on March 7, 2019
  • Google+ APIs and OAuth requests are being shutdown on March 7, 2019
    I got this email this morning: I believe this will affect my sign on to use BLGData. Is this correct and is there a work around?
    Hello Google+ Developer,
    The email below contains your most recent usage of Google+ APIs. Note: It includes Google+ OAuth scope requests, which are also affected by the Google+ shutdown. A prior email sent to active API callers did not include information about OAuth requests. One final reminder email will be sent in February to users who still have active API or OAuth request activity. What do I need to know?
    On March 7, 2019, all Google+ APIs and Google+ Sign-in will be shut down completely. This will be a progressive shutdown, with API calls starting to intermittently fail as early as January 28, 2019, and OAuth requests for Google+ scopes starting to intermittently fail as early as February 15, 2019. What do I need to do?
    Please update your projects listed below by March 7, 2019 and ensure they are no longer using Google+ APIs, or requesting Google+ OAuth scopes. The data below shows which Google+ API methods your projects have recently called, as well as Google+ OAuth scopes it has requested.
    Note: If you see calls to people.get, these can be the result of using the Google+ Sign-In feature in your application, which is now fully deprecated and is being shut down. Developers should migrate from the Google+ Sign-In feature to the more comprehensive Google Sign-in authentication system.
    Yep I got it too - looks like they are getting rid of Google+
    I have disabled Google+ in the next build
    Cheers,
    Bob
      Is there a different way to authenticate/sign in to use the plugin? Is it documented somewhere?
        It looks like they are only getting rid of Google+
        It should not affect the calendar service
        Cheers,
        Bob
          I think calendars could be affected. In my email it mentioned my calendar project, and OAuth. I hope i am wrong...
            Yes me as well. That is why I posted here looking for answers.
              I am pretty sure it is just Google+ that is being shutdown
              It would list your project because you likely have Google+ API turned on
              Cheers,
              Bob
                I got the same mail today... the project they are pointing at is my calendar api as well... As far I remember I never did anything with Google+ as I am not even using it.
                Will keep my fingers crossed
                -- Wim
                  Same here. I disabled Google+ API's in both projects I use and no effect on the calendar.
                    Bob if I understand you there will be a new BLGData version (ETA?) that does not use Google+ API or Google+ OAuth therefore we can forget about our BLGData project(s)? can you confirm and I will go back to sleep as your BLGData is hit in our house.. Mike
                    Computer: CUK Intel NUC7i7BNH
                    Op System: Windows 10 Pro - Work Station
                    HS Version: HS3 Pro Edition 3.0.0.435
                    Plug-Ins: BLBackup, BLGData, BLRoombaWifi, Device History, EasyTrigger, ImperiHome, Nest, PHLocation, Pushover 3P, Restart, Sonos, UltraCID3, UltraWeatherWU3, Z-Wave, and Jon00 scripts.
                      The only thing being removed is Google+
                      Everything else will stay the same
                      Cheers,
                      Bob
                        Thanxs.. So I can go back to sleep! Mike
