BLGData for Linux
This is a sticky topic.
  • #16
    That would take some work - add it as a feature request on my site
    Cheers,
    Bob
    • #17
      Blade Hi Bob,
      My ram is usually at 3.1-3.2gb used, when my pc is running after a long time.
      I saw recently that it bumped to near 4.0gb , so i monitored it with device history plugin.
      On the second picture You can see that blgdata is using 6.1% of 16 gb. and do have a lot a cpu time .
      AMD 2700x 16gb - Ubuntu 18.10 Server -
      • HS3 Pro 3.0.0.507
        AirplaySpeak - APCUPSD - Big5 - BLGData - CPS Links - CPS Tags - DeviceHistory - EasyTrigger - JowiHue - Kodi - LutronCaseta - McsMQTT - MediaController - MeiHarmonyHub - PHLocation2 - Pushover - SceneMaster - SqueezeBox - UltraLog3 - Z-Wave - Jon00 stuff - HTTP calls
      • Openhab 2.5 Milestone 1 AmazonEchoControl - Plex - SystemInfo
      • Home Assistant 0.87 Plex - Roku
      • Node-red 19.5
      • Deconz 2.05.59
      • Logitech Media Server 7.9.2
      • Plex Server
      • #18
        I am using BLGData v.37 . And only had the time to configure two handlers ( one active)
        • HS3 Pro 3.0.0.507
        • Node-red 19.5
        • Deconz 2.05.59
        • Plex Server
        • #19
          updates :
          now 6.6 %. I will turn off the plugin for now. I don't want my system to crash
          • HS3 Pro 3.0.0.507
          • Node-red 19.5
          • Deconz 2.05.59
          • Plex Server
          • #20
            disabled the plugin. now at 3 gb
            So it was using 0.86 gb ...
            • HS3 Pro 3.0.0.507
            • Node-red 19.5
            • Deconz 2.05.59
            • Plex Server
            • #21
              The plugin does use memory on Windows - This is the first time it has been run in Linux
              I will have to check and see what mine is using on Windows
              So on Linux you are seeing the memory continuously rise and never come back down?
              Cheers,
              Bob
              • #22
                No it never comes back down
                • HS3 Pro 3.0.0.507
                • Node-red 19.5
                • Deconz 2.05.59
                • Plex Server
                • #23
                  Hmmm ok - On windows mine is siting at 12mb of memory
                  Do you have a lot of events in your calendars and how many calendars?
                  Cheers,
                  Bob
                  • #24
                    Try out 3.0.38 in the beta section and let me know if it helps
                    Cheers,
                    Bob
                    • #25
                      Thanks . I just loaded it. Will let you know today.
                      Edit: I had to restart my servers a couple of times today. Will let you know tomorrow Blade
                      • HS3 Pro 3.0.0.507
                      • Node-red 19.5
                      • Deconz 2.05.59
                      • Plex Server
                      • #26
                        Same problem as before. Memory is now st 4.1% and will surely goes up during the day
                        • HS3 Pro 3.0.0.507
                        • Node-red 19.5
                        • Deconz 2.05.59
                        • Plex Server
                        • #27
                          Mono on Linux must not be as good of handling memory as Windows
                          What version of Mono are you running?
                          mono --version
                          Cheers,
                          Bob
                          • #28
                            5.18 the latest stable release
                            • HS3 Pro 3.0.0.507
                            • Node-red 19.5
                            • Deconz 2.05.59
                            • Plex Server
                            • #29
                              I am running:
                              Mono JIT compiler version 5.18.0.240
                              What about vbnc:
                              Visual Basic.Net Compiler version 0.0.0.5943 (Mono 4.7 - tarball)
                              Cheers,
                              Bob
                              • #30
                                Same as you , v 0.0.0.5943
                                mono is also 5.18.0.240
                                • HS3 Pro 3.0.0.507
                                • Node-red 19.5
                                • Deconz 2.05.59
                                • Plex Server
