How to get PluginFunction to return array of classes
  • #16
    Originally posted by bsobel View Post
    The code needed for the class definition needs to be available to the script and much more configuration is needed to make the script work
    No any configuration is required if (1) your plugin is local, and (2) the class definition is in the plugin exe, not a library. HS then will find the class definition itself.
    And that was original OP question - because Blade plugins provide this functionality. And we couldn't find out how. Not because we don't know how .NET remoting works. Because HS documentation doesn't explain the above two points.
