Description
This is a sticky topic.
  • Description
    The BLGData Plug-In for HomeSeer will allow the user to interface with Google Data for multiple users.
    • User can add unlimited Google users to the plug-in.
    • Calendars can be viewed for a user
    • User can create events for a calendar
    • User can view their contacts
    Cheers,
    Bob
    Hey Bob,
    I had a cobbled together Google Calendar reader using XML but that is going away apparently. Does you plugin use XML or the direct API?
    Thanks!
    Because of low usage, and in an effort to streamline our services, from 18 November 2015, XML feeds will no longer be available in Google Calendar. You're getting this message because you're currently viewing or sharing a link to one or more of your calendars using an XML feed.
    ~Bill
      Looks like your website is down if it is still: http://bladeplugins.no-ip.org/
      Updater has all your plugins unreachable. Later!
      ~Bill
        It should be back up
        Cheers,
        Bob
          XML Driven?
          I had a cobbled together Google Calendar reader using XML but XML is going away apparently. Does you plugin use XML or the direct API?
          Thanks!
          ~Bill
            Direct API
            Cheers,
            Bob
              Bob I am trying this out and I like it, good job.
              Is there anyway of using homeseer replacement variables in the message?
              Will
                Give me an example of what you are trying to do?
                Cheers,
                Bob
                  I am triggering the BLGData SMS feature using my GV number. It sends the SMS text with my message to my device perfectly.
                  I would like it to send an HS3 devicestring as the message using a HS replacement variable (ex. $$DTR:23
                    I do not think I have anything in the plugin that will do this now.
                    Cheers,
                    Bob
                      I would have to look but can you run a script or script command to trigger it?
                      Can you post a screenshot of what you are doing so I can see
                      Cheers,
                      Bob
