BLGData - Broken - haven't a got a clue.
    Hi All,
    As the title says BLGData is broken, I can see a couple of calendars I created about 6 months ago if I go via the web but cannot see them from BLGData. I installed the plugin and did eventually get it working although I really don't understand the bits and pieces. I had to change my google password (e-mail) and had to wait for it to work with HS for about 12 hours, I don't understand why it took this long but it is OK now. I have also updated my password in the plugin. I have tried to view my calendars and create a new one alas no joy. I suspect for someone that knows what they are doing this will be easy to fix. Along with a "war and peace" log entry I keep getting asked for "Enter google API authentication code" (what is this? or where do I find it?) I presume it is not my Client ID: or Client secret:. I am also asked to paste a code into the said box but it does not make a bit of difference it still does not work!
    Sorry about the length of the log entry:-
    Oct-17 18:16:54 Error Calling HSEvent in plugin BLGData, Instance :Object reference not set to an instance of an object.
    Oct-17 18:16:53 Warning Plugin BLGData is not responding but it is still running, not restarting yet.
    Oct-17 18:16:41 BLGData BLGData_gplus.GetHorizontalRule(): ERROR - Caught this exception: System.NullReferenceException: Object reference not set to an instance of an object. Server stack trace: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PluginFunction(String procName, Object[] parms) at Scheduler.hsapplication.PluginFunction(String plugname, String pluginstance, String func, Object[] parms) at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateP rocessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProce ssMessage(IMessage msg) Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IHSApplication.PluginFunction(String plugname, String pluginstance, String func, Object[] parms) at HomeSeerAPI.PluginAccess.PluginFunction(String procName, Object[] parms) at BLGData_gplus.GetHorizontalRule() in D:\Program Files (x86)\HomeSeer HS3\html\BLGData\BLGData_gplus.aspx.vb:line 25
    Oct-17 18:16:24 Error Calling HSEvent in plugin BLGData, Instance :Object reference not set to an instance of an object.
    Oct-17 18:16:11 BLGData BLGData_gplus.GetMainMenu(): ERROR - Caught this exception: System.NullReferenceException: Object reference not set to an instance of an object. Server stack trace: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PluginFunction(String procName, Object[] parms) at Scheduler.hsapplication.PluginFunction(String plugname, String pluginstance, String func, Object[] parms) at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateP rocessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProce ssMessage(IMessage msg) Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IHSApplication.PluginFunction(String plugname, String pluginstance, String func, Object[] parms) at HomeSeerAPI.PluginAccess.PluginFunction(String procName, Object[] parms) at BLGData_gplus.GetMainMenu() in D:\Program Files (x86)\HomeSeer HS3\html\BLGData\BLGData_gplus.aspx.vb:line 65
    Oct-17 18:15:54 Error Calling HSEvent in plugin BLGData, Instance :Object reference not set to an instance of an object.
    Oct-17 18:15:53 Warning Plugin BLGData is not responding but it is still running, not restarting yet.
    Oct-17 18:15:41 BLGData BLGData_gplus.Page_Load(): ERROR - Caught this exception: System.NullReferenceException: Object reference not set to an instance of an object. Server stack trace: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PluginFunction(String procName, Object[] parms) at Scheduler.hsapplication.PluginFunction(String plugname, String pluginstance, String func, Object[] parms) at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateP rocessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProce ssMessage(IMessage msg) Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IHSApplication.PluginFunction(String plugname, String pluginstance, String func, Object[] parms) at HomeSeerAPI.PluginAccess.PluginFunction(String procName, Object[] parms) at BLGData_gplus.Populate_Page_Data() in D:\Program Files (x86)\HomeSeer HS3\html\BLGData\BLGData_gplus.aspx.vb:line 172 at BLGData_gplus.Page_Load(Object sender, EventArgs e) in D:\Program Files (x86)\HomeSeer HS3\html\BLGData\BLGData_gplus.aspx.vb:line 120
    Oct-17 18:15:24 Error Calling HSEvent in plugin BLGData, Instance :Object reference not set to an instance of an object.
    Oct-17 18:14:54 Error Calling HSEvent in plugin BLGData, Instance :Object reference not set to an instance of an object.
    Oct-17 18:14:53 Warning Plugin BLGData is not responding but it is still running, not restarting yet.
    Oct-17 18:12:56 Error Calling HSEvent in plugin BLGData, Instance :Object reference not set to an instance of an object.
    Oct-17 18:12:53 Warning Plugin BLGData is not responding but it is still running, not restarting yet.
    Oct-17 18:12:45 BLGData BLGData_gplus.GetHorizontalRule(): ERROR - Caught this exception: System.NullReferenceException: Object reference not set to an instance of an object. Server stack trace: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PluginFunction(String procName, Object[] parms) at Scheduler.hsapplication.PluginFunction(String plugname, String pluginstance, String func, Object[] parms) at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateP rocessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProce ssMessage(IMessage msg) Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IHSApplication.PluginFunction(String plugname, String pluginstance, String func, Object[] parms) at HomeSeerAPI.PluginAccess.PluginFunction(String procName, Object[] parms) at BLGData_gplus.GetHorizontalRule() in D:\Program Files (x86)\HomeSeer HS3\html\BLGData\BLGData_gplus.aspx.vb:line 25
    Oct-17 18:12:26 Error Calling HSEvent in plugin BLGData, Instance :Object reference not set to an instance of an object.
    Oct-17 18:12:15 BLGData BLGData_gplus.GetMainMenu(): ERROR - Caught this exception: System.NullReferenceException: Object reference not set to an instance of an object. Server stack trace: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PluginFunction(String procName, Object[] parms) at Scheduler.hsapplication.PluginFunction(String plugname, String pluginstance, String func, Object[] parms) at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateP rocessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProce ssMessage(IMessage msg) Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IHSApplication.PluginFunction(String plugname, String pluginstance, String func, Object[] parms) at HomeSeerAPI.PluginAccess.PluginFunction(String procName, Object[] parms) at BLGData_gplus.GetMainMenu() in D:\Program Files (x86)\HomeSeer HS3\html\BLGData\BLGData_gplus.aspx.vb:line 65
    Oct-17 18:12:02 Event Running script in background:
    Oct-17 18:11:56 Error Calling HSEvent in plugin BLGData, Instance :Object reference not set to an instance of an object.
    Oct-17 18:11:53 Warning Plugin BLGData is not responding but it is still running, not restarting yet.
    Oct-17 18:11:44 BLGData BLGData_gplus.Page_Load(): ERROR - Caught this exception: System.NullReferenceException: Object reference not set to an instance of an object. Server stack trace: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PluginFunction(String procName, Object[] parms) at Scheduler.hsapplication.PluginFunction(String plugname, String pluginstance, String func, Object[] parms) at System.Runtime.Remoting.Messaging.StackBuilderSink._PrivateP rocessMessage(IntPtr md, Object[] args, Object server, Object[]& outArgs) at System.Runtime.Remoting.Messaging.StackBuilderSink.SyncProce ssMessage(IMessage msg) Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IHSApplication.PluginFunction(String plugname, String pluginstance, String func, Object[] parms) at HomeSeerAPI.PluginAccess.PluginFunction(String procName, Object[] parms) at BLGData_gplus.Populate_Page_Data() in D:\Program Files (x86)\HomeSeer HS3\html\BLGData\BLGData_gplus.aspx.vb:line 172 at BLGData_gplus.Page_Load(Object sender, EventArgs e) in D:\Program Files (x86)\HomeSeer HS3\html\BLGData\BLGData_gplus.aspx.vb:line 120
    Oct-17 18:11:26 Error Calling HSEvent in plugin BLGData, Instance :Object reference not set to an instance of an object.
    Attached also copy of the web page with the string.
    I do hope that some one understands this as I don't know where to start!
    All / any help appreciated .
    Peter
    PS Not sure if this is relevant here but my HS3 PC is Win 7 x64 and is currently up to date. HS3 is 3.0.0.176.
    Having similar problem; can see calendars via google/calendar, but not with plugin. Not getting same error messages; just that user doesn't have any calendars.
    Left Bob a message, so he is aware of it.
    Don
      This is odd because I cannot duplicate it here. I just tried my calendars again here and they work in the plugin
      I am not sure off the top of my head what is causing this.
      Have you made any other changes recently?
      BTW... on the accept screen from Google make sure you click Accept
      Cheers,
      Bob
        I haven't. However there have been some changes to HS3: I'm on 131. Oh yeah, the never ending MS patches...
        Don
          OK. If I assume this is due to a MS update, is there any way to trace this down? I suspect more of us are going to start running into this issue.
          Peter, are you sure about the HS3 version #?
          If you have fixed this, please tell all....
          Don
            BLGData - Broken.
            Hi Don & Blade,
            Oops getting HS & Z-Wave versions mixed up. I am actually on HS3 version 3.0.0.125. I haven't changed anything except for my password. Don't really have any idea when it went wrong, I have had the plugin for ages but not tried it except for setting it up until now.
            My idea is to use the calendar for announcing appointments over my PBX with a single phone page type facility, only just got the phones working so this was the next step.
            Sorry not a lot of help. As I said in the first post I really would not know where to start, took me enough time to get it working the first time round.
            Blade I did press accept on the accept screen but always receive "Enter google API authentication code" which gives a different code each time, once again I have no clue as to what this is!
            Can't think of anything else that might be relevant at this time.
            Peter
              BLGData - Broken - Fixed
              Thanks Blade,
              Downloaded 2.0.4.0 and all is O.K. now.
              The API thing is also now obvious!
              Will have to make some serious effort to use the plugin and get familiar with it, guess the first stop is the board.
              Once again thanks.
              Peter
                Glad to hear it is working for you. Still nonfunctional for me.
                Don
                  Hope it gets sorted soon
                  Hi Don,
                  Sorry to hear you are not up and running with V2.0.4.0, also sorry that I can be of absolutely no help at all to you!
                  Best of luck with it.
                  Peter
                    OK... Makes no sense but I deleted my account and recreated it, and that appears to have fixed it.
                    Thanks for the advice and encouragement.
                    Don
                      Also for me the plugin does not see the Google Calendar anymore since two days. Not via the interface, nor through the scripting I am using.
                      I deleted the account and readded it, but no luck either here.
                      What can I do?
                      Wim
                      -- Wim
                        Any windows updates?
                        Did you change anything on the computer?
                        The plugin has not changed
                        Cheers,
                        Bob
                          Blade,
                          All up to date, so yes, sure there have been windows updates in the past months.
                          HS3 has .143 since a week or two. No real changes since last saturday here on systemlevel. Since monday it does not work anymore here. I am only using this plugin to get the calendar info for my wakeup alarms, but it will not find the calendar anymore.
                          I have removed the user from configuration, readded it wil the api keys, generated new api keys and readded the user again. No go for the calendar.
                          The calender is still normally visible in the gmail account, so I am at loss what could have changed it? Even when I try to create a new calendar through the plugin, the plugin seems to ignore it, without errors.
                          Wim
                          To test I also enabled contacts. This seems to function as I do get a list there.
                          -- Wim
                            Very odd. Another user had this a few weeks ago.
                            Log a ticket on my web site and attach a debug log zipped of the calendars not showing.
                            I will check if there are any errors
                            Cheers,
                            Bob
                              Logs have been send, one with accessing calendars through the webinterface, another one through scripting.
                              Wim
                              -- Wim
