Event listing in a HS Device?
  • #91
    Originally posted by Pierre View Post
    This is a nice script.
    When formating the string, I would suggest using "<br>" instead of "<tr><td>", or using both, in order to show this device string in HStouch with some formating left.
    I also have made my way to format all-day events, recurring events, birthdays and events for the next days, witch was sometimes tricky.
    Hello.
    Mind sharing how you do this in the script?
    At least how to get today events in bold, and future events normal text.
    Thank you
    • #92
      There was an update of mono today. Chek if the issue is still there
      • #93
        Originally posted by jyrki69 View Post
        sparkman just helped me with the script not running under Linux.
        The fix was to change "Dim allEvents As Object()" to "Dim allEvents As Object".
        This script code now works perfect under Linux:
        Dim ParmArray() as String
        ParmArray = Parms.tostring.split(",")
        Dim tDevice as string = ParmArray(0)
        Dim tCalendar as string = ParmArray(1)
        Dim tDays as integer = cint(ParmArray(2))
        Dim myemail as string="youremail@gmail.com"
        Dim msg as string = ""
        allEvents = hs.PluginFunction("BLGData", "", "GetCalendarEventsForXDays", new Object(){myemail,tCalendar, tDays})
        msg="<table>"
        For Each ev As Object In allEvents
        msg = msg & "<tr><td> " & ev.StartTime & " - " & ev.Name & "." & "</td></tr>"
        Next
        msg=msg & "</table>"
        if msg="" then msg="No Events Scheduled"
        hs.SetDeviceString(tDevice, msg.Trim, true)
        End Sub
        How much memory does this plugin comsume on your linux machine?
        • #94
          jyrki69
          Here is a copy of the script I use, and that I did not change since the message your are referring to.
          Your must change the settings under "user's settings"
          PHP Code:
          This is script to copy all calendar's appointments for today and tomerrow
          The string can then be used easyly in HSTouch, or by speaking
          'You must have BLGData plugin installed and running, with at least one agenda in the setup into a device's string.
          'You must also create or use a device where to store, use it's adress iin the settings below
          Sub Main
          (ByVal Parm As Object)
          dim chaine as string=""
          dim User_email,Calendar_name,prefix_heure as string
          dim NumberofDays
          as integer
          dim TodayGCal_device
          as integer
          dim jour
          as string DateTime.Now.Date.Tostring("dd/MM/yyyy")
          dim heure as string Now.Tostring("HH:mm")
          dim today_txt,today_txt_allday,tomorrow_txt,tomorrow_txt_allday,bckgrd_color,event_name as string
          'user's settings=========================================================================
          TodayGCal_device=760 'the adress of the device where the events are going to be dumped in the string
          User_email= "yourname@gmail.com" '
          user email as in the BLGData plugin
          Calendar_name
          ="xxxxxxxxxxxxx@gmail.com" 'Calendar name as in the BLGData plugin
          NumberofDays=1 '
          number of days to fetch ahead
          bckgrd_color
          ="#A0EAE7"
          today_txt=" A "
          today_txt_allday=""
          tomorrow_txt="DEMAIN A "
          tomorrow_txt_allday="DEMAIN "
          'end of user'
          allEvents hs.PluginFunction("BLGData""""GetCalendarEventsForXDays", new Object(){User_email,Calendar_name,NumberofDays})
              Try
          'Log("GoogleCalendar Script 1 Starting")
           chaine="<table bgcolor='" & bckgrd_color   & "'>"
          hs.writelog("Info"" A: "  ev.StartTime " Pierre: " ev.Name)
          ' on écarte aussi les événements dont l'heure de fin est passée
          if ev.StartDate=jour and ev.EndTimeheure then
          'detecte les évènements journee entière pour aujourd'hui
          if ev.StartTime="00:00" and ev.Endtime="00:00" then
                                                      chaine
          chaine "<tr><td>" today_txt_allday chaine "  " ev.Name ".</td></tr>"
          else
          chainechaine "<tr><td>" today_txt ev.StartTime ": " ev.Name ". </td></tr>"
          end if
                     elseif
          ev.StartDate>jour then
                                                      chaine= chaine & "<tr><td>" & tomorrow_txt_allday & ev.Name & ". </td></tr>"
                                          else
                                          chaine= chaine & "<tr><td>" & tomorrow_txt  & ev.StartTime & " : " & ev.Name & ". </td></tr>"
                                          end if
                     end if
          chaine=chaine "</tr>"
              '  Log("--- End Of Entry ---")
              Next
          Log("End Of GoogleCalendar Script")
          chaine=chaine "</table>"
          ' Log("End Of GoogleCalendar Script 1")
               Log(chaine)
          if string is empty the device value will be set to 0
          if striptags(chaine)="" then
                  hs
          .SetDeviceValueByref(TodayGCal_device,0,true)
          hs.setdeviceString(TodayGCal_device,"",true)
            else
          'if there is a string set the device value to 100
                  hs.SetDeviceValueByref(TodayGCal_device,100,true)
                  hs.setdeviceString(TodayGCal_device,chaine,true)
           end if
              Catch ex As Exception
                  Log("Exception: " & ex.Message.ToString)
              End Try
          End Sub
          Sub Log(ByVal ParStr As String)
              hs.writelog("Ald_gcal_tostring", ParStr)
          End Sub
          Function striptags(Byval chaine as string)'
          enleve les tags
          dim debut
          fin as integer
          'enleve les tags
          hs.writelog "signature_mail",chaine
          do
          'cherche les <
                  debut = Instr (chaine,"<")
               if debut <>0 then '
          boucle a garder autrement erreur
          'hs.writelog "message",debut
          cherche les >
          fin Instr (chaine,">")
          'msgbox fin
          enleve ce qui est entre les 2 bornes
                 chaine
          left(chaine,debut-1) & right(chaine,len(chaine)-fin)
          'hs.writelog "signature_mail",chaine
                end if
              loop while debut<>0
          msgbox data
          return chaine
          end
          Function
          • #95
            jyrki69
            PHP Code:
            Sub Main
            dim NumberofDays
            as integer
            as integer
            dim jour
            Calendar_name
            NumberofDays=1 '
            bckgrd_color
            ="#A0EAE7"
            today_txt=" A "
            today_txt_allday=""
            'end of user'
            Try
            chaine
            else
            end if
            elseif
            else
            end if
            end if
            Next
            Log(chaine)
            hs
            else
            end if
            End Try
            End Sub
            End Sub
            enleve les tags
            dim debut
            fin as integer
            'enleve les tags
            do
            'cherche les <
            if debut <>0 then '
            cherche les >
            'msgbox fin
            chaine
            end if
            loop while debut<>0
            msgbox data
            return chaine
            end
            Function
            Do you run this under Linux or Windows?
            • #96
              Windows
              • #97
                jyrki69
                PHP Code:
                Sub Main
                dim NumberofDays
                as integer
                as integer
                dim jour
                Calendar_name
                NumberofDays=1 '
                bckgrd_color
                ="#A0EAE7"
                today_txt=" A "
                today_txt_allday=""
                'end of user'
                Try
                chaine
                else
                end if
                elseif
                else
                end if
                end if
                Next
                Log(chaine)
                hs
                else
                end if
                End Try
                End Sub
                End Sub
                enleve les tags
                dim debut
                fin as integer
                'enleve les tags
                do
                'cherche les <
                if debut <>0 then '
                cherche les >
                'msgbox fin
                chaine
                end if
                loop while debut<>0
                msgbox data
                return chaine
                end
                Function
                Thank you so much!
                • #98
                  I need to check the status as of now when I get home. I have ran some lookups on the memory usage because of the issues stated in the other thread, and in my setup it did not consume a whole lot of memory like mentioned there.
                  • #99
                    Quick question to our script experts, I've been using the GCalendar script for a while and was thinking it would be nice to have a Virtual Device with tomorrows calendar events but the parameter tDays (0,1,2,3..) outputs; Day 1, Day1+Day2, Day1+Day2+Day3 but it would be nice to have a single day output what do I have to do to make it so? thanxs in advance Mike
                    Parmeters: 402,My Calendar,1
                    sub Main(ByVal Parms As Object)
                        Dim tDevice = ParmArray(0)
                        Dim tCalendar = ParmArray(1)
                        Dim tDays = cint(ParmArray(2))
                            Dim myemail as string="Myemail@XXX.com"
                            allEvents = hs.PluginFunction("BLGData", "", "GetCalendarEventsForXDays", new Object(){myemail,tCalendar,tDays})
                            msg = msg & ev.StartTime & " - " & ev.Name & ". " & "</br>"
                        Next
                    End Sub
                    Computer: CUK Intel NUC7i7BNH
                    Op System: Windows 10 Pro - Work Station
                    HS Version: HS3 Pro Edition 3.0.0.435
                    Plug-Ins: BLBackup, BLGData, BLRoombaWifi, Device History, EasyTrigger, ImperiHome, Nest, PHLocation, Pushover 3P, Restart, Sonos, UltraCID3, UltraWeatherWU3, Z-Wave, and Jon00 scripts.
                    • Originally posted by Pierre View Post
                      jyrki69
                      PHP Code:
                      Sub Main
                      dim NumberofDays
                      as integer
                      as integer
                      dim jour
                      Calendar_name
                      NumberofDays=1 '
                      bckgrd_color
                      ="#A0EAE7"
                      today_txt=" A "
                      today_txt_allday=""
                      'end of user'
                      Try
                      chaine
                      else
                      end if
                      elseif
                      else
                      end if
                      end if
                      Next
                      Log(chaine)
                      hs
                      else
                      end if
                      End Try
                      End Sub
                      End Sub
                      enleve les tags
                      dim debut
                      fin as integer
                      'enleve les tags
                      do
                      'cherche les <
                      if debut <>0 then '
                      cherche les >
                      'msgbox fin
                      chaine
                      end if
                      loop while debut<>0
                      msgbox data
                      return chaine
                      end
                      Function
                      Pierre, thanxs for sharing your script, quick translation question "Chaine" does that stand for Chain or is there some other meaning/term like (msg)? Mike
                      UPDATE: Pierre, per chance do you have the formatted or indented version of your script? Mike
                      • MNB
                        Mike, "Chaine" stands for "chain" of characters but it is just a variable and you can change its name for whatever you want.
                        I have formated the code in a better way, I hope it helps.
                        I am using 3 differents version of this script, one for each of my calendars, that only differs by the background color, and the other user's settings.
                        PHP Code:
                        'This is script to copy all calendar's appointments for today and tomerrow
                        'The string can then be used easyly in HSTouch, or by speaking
                        You must have BLGData plugin installed and runningwith at least one agenda in the setup into a device's string.
                        Sub Main(ByVal Parm As Object)
                        dim NumberofDays as integer
                        dim TodayGCal_device as integer
                        dim jour as string = DateTime.Now.Date.Tostring("dd/MM/yyyy")
                        dim heure as string = Now.Tostring("HH:mm")
                        User_email
                        "yourname@gmail.com" 'user email as in the BLGData plugin
                        Calendar_name="xxxxxxxxxxxxx@gmail.com" '
                        NumberofDays
                        ='number of days to fetch ahead
                        bckgrd_color="#A0EAE7" '
                        background color
                        today_txt
                        =" Today"
                        today_txt_allday="All day "
                        tomorrow_txt="Tomorow at "
                        tomorrow_txt_allday="Tomorow "
                        'end of user'
                        Try
                        ' we get rid of events that are already done    +-----  on écarte aussi les événements dont l'heure de fin est passée
                        'lets detect "all day events"  --**--  detecte les évènements journee entière pour aujourd'hui
                                chaine
                        else
                        end if
                            elseif
                        'detects "all day" events =----=  detecte les évènements journee entière
                                    else
                                end if
                            end if
                            Next
                            Log(chaine)
                                hs
                                else
                        end if
                        End Try
                        End Sub
                        End Sub
                        Function
                        striptags(Byval chaine as string)'gets rid of html tags *---*   enleve les tags
                        dim debut, fin as integer
                        gets rid of html tags +---+  enleve les tags
                        do
                        search for <    *--*  cherche les <
                        debut Instr (chaine,"<")
                            if
                        debut <>0 then 'boucle a garder autrement erreur
                        'search for >   *----* cherche les >
                                fin = Instr (chaine,">")
                        msgbox fin
                        ' delete what is between *----*enleve ce qui est entre les 2 bornes
                                chaine = left(chaine,debut-1) & right(chaine,len(chaine)-fin)
                            end
                        if
                        loop while debut<>0
                        'msgbox data
                        return chaine
                        end Function
                        • Pierre, many thanxs for the comeback, I will try your updated script "as is" before anglicizing it to verify that it works. When I took the previous version I got an error message within my HS Log as follows;
                          Mar-06 6:03:54 PM Error Initializing script engine: Length cannot be less than zero. Parameter name: length
                          Mar-06 6:03:54 PM Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/HS3 GCalendar Events Script (Single Day).vb("Main")
                          Mar-06 6:03:54 PM Event Event Trigger "Calendar Data BLData Calendar Events (Single Day)"
                          Mar-06 6:03:54 PM Event Event Calendar Data BLData Calendar Events (Single Day) triggered by the event page 'Run'
                          Update:
                          Was still getting the message above even with the latest update, so I tried one of my shorter known working script and had the same results.. I deleted the event and created a new one and "wala" it's now working (stray cosmic rays?)
                          Pierre thanxs for the script, love the color within my calendar virtual device! But I'm noticing that I have today and tomorrows calendar events with "Tomorrow" for both today and tomorrow calendar events, what am I missing? Is it possible to have just tomorrow's calendar events? Mike
