Yea I figured that. I will have to still fix that
Event listing in a HS Device?
Thanks, no rush. Have a good night.Bryan
Software/Hardware: Win10 Pro, HS 3 Pro, HS Touch, Echo, Edgeport/4, Z-Net w/88 Devices, Insteon PLM w/19 Devices, Nest, GC-100-6, W800RF32A, WS-2080 Weather Station (KMADRACU10)
Plug-in/Scripts: Alexa API, BLBackup, BLGData, BLLED, BLLock, BLRF, BLTVGuide, Blue Iris, BLUPS, Current Cost 3P, DirectTV, FitbitSeer, Insteon, Nest, Pushover 3P, Random, Restart, Tasker, UltraGCIR3, UltraWeatherWU, Z-Wave
Bryan
This is a nice script.
When formating the string, I would suggest using "<br>" instead of "<tr><td>", or using both, in order to show this device string in HStouch with some formating left.
I also have made my way to format all-day events, recurring events, birthdays and events for the next days, witch was sometimes tricky.Visit zee e-maison : http://www.e-maison.com
Bob, I like your plugin so far. What I want to accomplish is to run an event every half hour and determine if there is any calendar event matching that specific date and time. If there is a match, ideally I would like to display another HSTouch screen on the top of the current one indicating that I have a calendar event that needs attention. Would it be possible?
In addition to this request, I'm able to display the entire calendar on my HSTouch but it is very slow, sometime it takes 2-3 minutes to display the calendar. there is anything else that I could do to make it faster?
Aldo
Blade,
This is unusual for you to not reply, perhaps you did not see this post. I like what I see so far, would it be possible to add a trigger to trigger on the date and time? I would create an event that checks every hour if there is anything on the calendar and triggers if any.
Aldo
hstouch help?
greetings,
I've got my data pulling in from the cal and i've got it placing it into several different "devices" (day0, day1, day2, etc)
my issue is in hstouch, i'm referencing the devices via the rss tracking thingy, and all it shows on the tablet is "Text". (the device status, shows up just fine in the designer)
any thoughts? ideas? help?
@Pierre, can or some else post how you formatted your virtual device outputs also as this is a information virtual device is there a way to get rid of the On/Off icon? I thought that if I deleted the On/Off icons within the Status Graphics Tab on the virtual device they would be removed.. no such luck they still are there any help would be greatly appreciated.Computer: CUK Intel NUC7i7BNH
Op System: Windows10 Pro - Work Station
HS Version: HS4 Pro Edition 4.2.19.0
Plug-Ins: AK Weather 4.0.5.25,APCUPSD 3.3.2.3,BLBackup 2.0.63.0,BLEditor 2.0.11.0,BLGData 3.0.55.0,BLOccupied 2.0.28.0,BLShutdown 1.0.6.0,Blue-Iris 3.1.3.33206,Device History 3.2.0.2,EasyTrigger 3.0.0.76,Harmony Hub 4.0.14.0,iRobot 5.22.41.1,JowiHue 4.0.8.7,Nest 3.0.0.34,NetCam Plugin 1.0.0.5,PHLocation2 3.0.0.64,Pushover 4.0.10.0,Random 3.0.0.2,Restart 1.0.0.7,Ring 1.0.0.9,SDJ-Health 3.1.1.3,Sonos 3.1.0.59,Sonos4 4.0.1.12,UltraCID3 3.0.6681.34300,UltraMon3 3.0.6554.33094,UltraNetCam3 3.0.6413.20219,Unifi 4.0.32.0,Zigbee 4.0.11.0,Z-Wave 4.0.3.0, and Jon00 scripts.
What do you mean by formatted virtual device?
Virtual devices are rich with options. You might want to check out Randy's thread in the event clinic forum about them: https://forums.homeseer.com/showthre...29#post1248729Originally posted by rpradeThere is no rhyme or reason to the anarchy a defective Z-Wave device can cause
EDIT: I'm good now. My problem was to many calendars and wasn't searching the right one. I was expecting to see the "no events scheduled" which still appears not to work, but when I added some test events to the right calendar I was able to get my Device to update and show that info.
Ok So I need a bit of help here.
I created a virtual device #602
I added my email in the script (bottom circle in my pic)
The top circle in the pic I have no idea where the Y10 comes from but I see it referenced in the 2nd script. My virtual device has the last changed time there instead and not sure if thats an issue or not.
The comes the middle circle or the perameters. my guess but correct me if I'm wrong is
Number of virtual device, name of the calendar (for me this was my email again) and the days I want to get (which I tested 1, but maybe it's supposed to be zero?)
Now I no longer get any errors in the log but I also get a virtual device that will change the "last change" time but not update the string with any info.
I'm not sure if I created the virtual device wrong or have something wrong in the script, but I can't find out where it outputs "no events scheduled" or the events as it's not doing it in my virtual device.
Any help would be useful.
Thanks,Last edited by integlikewhoa; June 19, 2017, 05:52 PM.
Is there any way to get info on all calendars into one daily device?
I have calendars that I follow from work, my kids sports team, my kids school, holidays and so on. SO I have like 6 calendars and some of them are updated and maintained by others (kids school and kids sports team with changing games) so Importing them to my main calendar once doesn't keep them accurate.
Right now it looks like I would have to run a separate event for each one unless I don't know the trick.
Is there a way to reference "ALL" calendars vs. one at a time in the parameters?
What about when I also need all my wifes calanders also. So multi user and multi calendar?
