Update Failed
  • Update Failed
    For the last few itirations of BLGData I haven't been able to update, just get a failed to update message. I have been just replacing the HSPI_BLGData executable and the help file. Is this all I need?
    It appears that the plugin doesn't shutdown when I try to update via the Interface page. I have tried to delete the HSPI_BLGData.exe file and can't as it is in use, even if I disable it.
    Any suggestions?
    Don
    I went through this yesterday also. What finally got it working for me again was to disable BLGData and restart HS3. Then it would finally update.
    Originally posted by rprade
      So, did you update through the additional interfaces? When I disable the plugin, the checkbox to update goes away.
      Don
        When I disabled the plugin I still had the check box I believe.
