Blade I have a registered copy of your BLGData plugin.
I have tried every suggested fix in this forum to no avail.
My HS3 instance becomes unresponsive after I try and setup my first user.
When I click on 'Calendar', under this user the browser just 'spins' until I get the following error message from your plugin window:Error finding plugin in GenPage: Object reference not set to an instance of an object.
I have double checked, and I have no duplicate DLL's in my root HS3 directory.
I have disabled, removed, and manually deleted all traces of the BLGData plugin from all folders under my HS3 install; and then reinstalled.
I have a Google Apps account for my email, and have setup an app password as I have 2 factor authentication enabled. I have setup my project and API in the Google developer console, using oath2 and have copied and pasted my ID and Secret. I have also enabled the Calendar API.
If you look in my logs, it just shows the error I have in my Title line.
Anymore suggestions?
Thank you for your time and excellent plugins!
Anthony
Anthony
