Holiday mode?
  • Holiday mode?
    The primary basic reason I want to use this plugin is to have anything that is entered in a specific calendar "Holidays in Canada", if there is anything listed on that day it will toggle a virtual device "Holiday" with a value of "Yes" or "No". Reason being is that I have an event that turns the lights on weekday mornings when the house is Occupied (also another virtual device), but when it's a holiday...the event still runs. So the night before I either have to disable the event or else I have to kill the lights that turn on that morning.
    What is the easiest way to do this?
    I too have wondered about the best way to manage this. I've been caught on those statutory holidays to find my wake up lights coming on at 5:45.
    Robert
      Robert
      Yep it kills the WAF, so to automate the lights not being automated that morning would be superb.
      The holiday calendar I am using is a "feed" (probably not the correct term) that is auto populated so year after year it's always accurate. I don't have to manually enter anything in, so to have this plugin find something entered in means it's a holiday and then I can kill events before they even run.
        You should be able to do this.
        In the event description, you should be able to put the following:
        HS[ControlDevice~A1~On]
        This would turn A1 ON when the start time of the event occurs
        You can also use the address or full device name as well
        Can you try something like this?
        Cheers,
        Bob
          I'm just not sure where to start...I'll try and read into the tutorials to get an idea. As I just started the trial a few days ago and just linked my calendars to it...but there are no HS events that are set up with BLGData, and the setup is just something new to learn. I was just hoping there was a basic tutorial on how to initiate an event based on something in the calendar, then I'll have a better idea getting up to speed. I'll do some more poking around on the forum and reading the guide.
            If you have the plugin setup and your calendars are showing in the plugin then that is good
            Go to your Holidays calendar and click on the event
            In the event description type: HS[ControlDevice~A1~On]
            Of course use the device code you want
            When that event start time occurs it should control the device you enter
            Cheers,
            Bob
              Wow that's nuts. Now all this relies on an internet connection correct? It doesn't pull scheduled event and save it to the plugin? A simple scenario would be to have the internet go down through the night and the plugin not connecting which would then not turn on the lights in the morning.
              I can get it to turn on a device at a specific time with the use of my calendar, however the Canadian Holiday calendar is something I subscribed to under "Interesting Calendars" with Google. So it pulls those holidays into my calendar so I can view it. However is there a way for the plugin to see that there is something entered in a particular calendar (regardless of what it is) and to then disable an event for that day? The reason being is that this holiday date is not editable, so I couldn't put in the appropriate code to kill an event.
                OK I see what you mean. No one has ever brought that up before - you are the first. I can see the issue.
                Add a feature request on my site for this so I have a record of it. This will take some thought
                Cheers,
                Bob
                  I think I was making this more complicated than it needs to be. I'll just go through my calendar and see what there are for Canadian holiday's then use the description as the trigger to run an event to toggle a virtual holiday device on or off. The description shouldn't change from year to year, unless we as a society become even more politically sensitive.
                  I'm buying the plugin today.
                    OK so you are good now or do u still need the feature?
                    Cheers,
                    Bob
                      No I think this works just fine. The only question is that these holiday entries are "All day" events. So this will trigger the Holiday mode at 12am, which is perfect so any events that day that are allowed to run can. However is there a way to have the holiday mode toggle back at 11:59pm? So another trigger at the end of the calendar entry?
                      Or is that what I would put in the "After Command:" of the BGData handler? Or have a 1440 minute (24hrs) offset value and have HS[ControlDevice~Holiday~Off]? The reason being is I could just use a simple HS event to toggle the status back at 11:59pm, but it would be ideal if the plugin could contain all the automation to switching the status on and off based on the Google calendar entry.
                      A good reason would be if we knew we were going to be on holidays for a few days, my wife doesn't need to make a calendar entry, she could simple turn the virtual holiday device on, but at 11:59pm it won't have a "dumb" event revert it back to off. Which would then force her to turn it back on every day.
                      Let me know what you think.
                        You could set the start time to 12:00 AM and the end time to 11:59 PM
                        Try that out
                        Cheers,
                        Bob
                          So Conrad, what was your final solution for holidays
                          Computer: CUK Intel NUC7i7BNH
                          Op System: Windows 10 Pro - Work Station
                          HS Version: HS3 Pro Edition 3.0.0.435
                          Plug-Ins: BLBackup, BLGData, BLRoombaWifi, Device History, EasyTrigger, ImperiHome, Nest, PHLocation, Pushover 3P, Restart, Sonos, UltraCID3, UltraWeatherWU3, Z-Wave, and Jon00 scripts.
