Trying to upgrade to the latest version of BLLED. Everything seems to load fine in the log but when I try to access the sign it will disconnect in the log. Sometimes a blank page instead of the sign setup.
It seems to load then stop. I've stopped and started and rebooted. Uninstall and reinstalled also with no luck. Any suggestions?
Legacy-Plugin
BLLED info
Sign queue processing has started
HomeSeer
Starting Plug-In
Plugin BLLED started successfully in 353 milliseconds
Legacy-Plugin
BLLED start
BLLED plug-in has been initialized
Legacy-Plugin
BLLED start
No DOT files have been assigned to BLLED!
Legacy-Plugin
BLLED start
No messages have been assigned to BLLED!
Legacy-Plugin
BLLED start
LED Signs have been loaded.
Legacy-Plugin
BLLED start
Loaded configuration successfully
Legacy-Plugin
BLLED start
BLLED version is: 2.0.1.0
Legacy-Plugin
BLLED start
Initializing BLLED...
HomeSeer
Starting Plug-In
Initializing plugin BLLED ...
HomeSeer
Starting Plug-In
BLLED loaded in 15028 milliseconds
HomeSeer
Info
Plugin BLLED has connected. IP:127.0.0.1:44346
HomeSeer
Warning
I/O interface BLLED is down, executable is not running, restarting ...
HomeSeer
Info
Plugin BLLED with ID: and Instance: has disconnected
Date/time=12/24/2021 6:27:35 PM MST
Version=HS4 Pro Edition 4.2.6.0 (Linux)
MONO Version=Mono JIT compiler version 5.18.0.240 (Debian 5.18.0.240+dfsg-3 Sat Apr 20 05:16:08 UTC 2019)
License=Registered
Confguration File=/home/pi/HomeSeer/Data/HomeSeerData.json
Uptime=0 Days 0 Hours 15 Minutes 50 Seconds
Device Count=437
Event Count=51
Plugins Enabled=RaspberryIO:,Global Cache Pro:,BLLAN:,Current Cost 3P:,X10:,RFXCOM:,NetCam Plugin:,HS MyQ:,rnbWeather:,Omnistat 3:,PHLocation2:,BLBackup:
Modules/Threads=73 Modules, 77 Threads
Available Threads=399
HomeSeer Memory Used=111 Mbytes
Plugins Installed=BLBackup 2.0.63.0,BLLAN 2.0.45.0,BLLED 2.0.1.0,Current Cost 3P 0.0.0.42,Global Cache Pro 5.0.0.59,HS MyQ 4.0.8.0,NetCam Plugin 1.0.0.5,Omnistat 3 3.3.0.0,PHLocation2 3.0.0.64,Rain8 3.0.0.7,RaspberryIO 3.0.0.18,RFXCOM 30.0.0.41,rnbWeather 4.2.0.0,ThinkingCleaner 3.0.1.0,X10 3.0.0.50
12/24/2021 6:44:19 PM
Legacy-Plugin
BLLED info
HomeSeer
Starting Plug-In
Legacy-Plugin
BLLED start
Legacy-Plugin
BLLED start
Legacy-Plugin
BLLED start
Legacy-Plugin
BLLED start
Legacy-Plugin
BLLED start
Legacy-Plugin
BLLED start
Legacy-Plugin
BLLED start
HomeSeer
Starting Plug-In
HomeSeer
Starting Plug-In
12/24/2021 6:44:04 PM
HomeSeer
Info
12/24/2021 6:44:02 PM
HomeSeer
Warning
12/24/2021 6:43:48 PM
HomeSeer
Info
License=Registered
Device Count=437
Event Count=51
