Thanks Bob!
BLLED is in development
This is a sticky topic.
Originally posted by sparkman View PostHi Bob,
Have you had a chance to look at this? It's causing some WAF issues . Let me know if you need me to log on your web-site.
Al
I'm finally making progress with these devices. I've found some things that feel like bugs or my not understanding how to use everything.
If I enter text between transition and font commands, my first character is deleted. Sometimes it actually generates an error or problem if I don't add a trailing space as well.
I'm trying to do everything via events but not quite there yet for me. Pretty close though.
When I create a message in an event does it override permanently or just once the message sent during sign init?
Is there a sample setup we could use to see everything work? Like a plugin demo setup we can use to reset to plugin demo mode?huggy_d1
Automating made easy
Hi Bob,
Woke up this morning and HS was behaving strange. When I started checking into it, the log was filling up with error messages related to BLLED which started at about 5 AM this morning. I had to kill the HSPI_BLLED.exe process to get it to stop as it was not responding to requests to shut down the plug-in. After re-enabling it, it worked fine for a few minutes and then it started errorring out again. I turned on debug logging and recreated the issue and captured a debug log along with the HS log entries. Can you take a look to see what might be causing this? The plugin has been running great, but I did see similar issues when I added a second BB that's hanging of one of the serial ports on a Global Cache GC-100. It had been working fine since however. I can communicate to the GC-100 with no problems and don't see any errors relating to it dropping of the network, but I'm suspecting something with it is triggering the problem.
AlAttached FilesHS 4.2.8.0: 2134 Devices 1252 Events
Z-Wave 3.0.10.0: 133 Nodes on one Z-Net
Thanks Bob, yes seems like HS wasn't able to talk to the plugin for some reason. In the past I was able to kill the plugin and restart it to clear it up, but I ended up having to restart my HS server. Does the plugin deal gracefully with devices it can no longer communicate to in case there's a network interruption (for devices connected remotely)?
AlHS 4.2.8.0: 2134 Devices 1252 Events
Here's the config for a LED sign:
Code:textLabel_A={callstring=1} textLabel_size_A=100 textLabel_size_B=100 textLabel_B={callstring=2} startupSequence=ABCDEFGHIJKLMNOPQRSTUVWXYZ stringLabel_1=[datetime=HH:mm|update=15] stringLabel_size_1=100 stringLabel_2=[datetime=dd/mm/yyyy|update=300] stringLabel_size_2=100
(And also; what is this "size" field? The size of what?)HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Running on Windows 10 (64) virtualized on ESXi (Fujitsu Primergy TX150 S8).
Blade, if you have the time, I really would like to get "proper" time formatting...HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Originally posted by Moskus View PostBlade, if you have the time, I really would like to get "proper" time formatting...
See the post I made before that one (three posts up).
In short: I'm using the time format "HH:mm", but the sign displays "06:15" instead of "18:15".HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Not to hijack Bob's thread here, but for those in the US who didn't get their fill of signs from Bob, there is a few left of a very good deal on EBay
There's only a few left, and they don't come with power supplies or data cables. Seems like a great backup for the ones we got from Bob in case they go bad.
Steve
Originally posted by Moskus View PostSee the post I made before that one (three posts up).
Log a ticket on my site for this and capture the issue with debug logging enabled. Then disable debug logging and attach the BLLED-Detailed.log zipped to the ticket.
Make sure you delete any previous logs first.
