As you know, the betabrite memory is not very large. It is very picky and all memory must be allocated before it is used.
DOT files use memory as well as text labels and string labels and all memory has to be allocated up front or strange things will occur on the sign.
I will be changing the plugin so that you will have to specify the text labels, string labels and DOT labels that will be in use for each sign. DOT files will change as well and will be assigned to a label (A-Z) when created. The more labels you use the more memory that is consumed on the sign. If you use too much memory the DOT files tend to not work properly.
Please stop using the DOT files in the plugin until I release a new build.
