Wiring the power supply
  • Wiring the power supply
    I've finally received the LED signs (yay!) and I'm about to add a connector to my power transformer (from 220V to 110V).
    I need to be sure:
    The green one is the ground, correct?
    I have no idea but.
    Hi Moskus,
    I have no idea but I'd start looking on the web.
    Hopefully someone on here will have been there, done it and got the t-shirt.
    best of luck.
    Peter
      I did, but I'm still unsure, so that's why I'm asking...
        Yes, green is the ground.
        Cheers
        Al
          Green = Ground
          Black = Hot
          White = Neutral
            Excellent! Thanks, guys!
