Help with Script Command
  • Help with Script Command
    I am trying to run a BLLED command as an immediate script command in an Event versus in a script. The command I am trying to have run is:
    hs.PluginFunction("BLLED", "", "SetDateTime", new Object(){1})
    When I type the statement into the Event HS adds the "&" in front but when I execute the event I get the following error in the log:
    Running script(2) &hs.PluginFunction("BLLED", "", "SetDateTime", new Object(){1}), init error: Expected end of statement
    I also tried it without the outer parenthesis but that just resulted in a syntax error as well.
    Any suggestions on what obvious thing I am doing wrong? Thanks!
    See this bug report (and resolution).
    Cheers
    Al
      Thanks Al!
      I think I'll try to get fully transitioned to HS3 and somewhat stable before I venture into the beta's to get that working. Will just use a script call for now instead of an immediate command.
        Having trouble with scripts
        I don't know much about scripts so I don't know if I am doing something wrong or it is a bug yet with HS3. Below is my script for led sign 2 for a hard reset. and then the error the log shows. Can someone help me?
        Sub Main()
        hs.PluginFunction("BLLED", "", "Reset", new Object(){2,TRUE})
        End Sub
        Error Running script, script run or compile error in file: C:/Program Files/HomeSeer HS3/scripts/LED.txt1025:Expected end of statement in line 3 More info: Exception from HRESULT: 0x800A0401
          Sub Main()
          End Sub
          Do you have a .vb extension on the script? If so the script needs to look like this.
          Sub Main(parm as object)
          End Sub
          -Rupp
            I am thinking that the script is not correct:
            Try this:
            If you are using multiple instances, make sure you specify your instance
            This example uses no instance
            Sub Main(ByVal parm As Object)
                hs.PluginFunction("BLLED", "", "Reset", new Object(){2,True})
            End Sub
            Cheers,
            Bob
              It was the file extension that caused the problem. I left it as a txt and it worked when changed to vb.
