Event setup question
  • Event setup question
    On the event trigger screen there is a box labeled "Device Code to store log file data: ".
    What is this used for and what goes in there. It doesn't show up in the 'Help'.
    I tried putting in the code 'V34' for a virtual device I have to see what might happen, but nothing happened to my V34 device when I triggered the event.
    Dick
    HS PRO 2.5.0.81, WinXP, IE8, Shuttle XS35V3, 2.13GHz, 4GB, 40GB SSD drive, AC-RF2, ADIOcelot, Message Server, TI103, SNEVL CID, pjcOutlook, MCSTemperature, Powertrigger, BLBackup, BLFloorplan, BLIcon, BLOccupied, BLRadar, BLRfid, BLLogMonitor, ACPUPSD, UltraECM, WeatherXML & Stipus' script connector. 500+ devices, 260+ events, 1-wire weather station + temp/humidity sensors & Oregon Scientific temp & humidity sensors & 2 Brultech ECM-1240s
    For that you may have to wait till Blade is done vacationing. I never used that feature, I wonder if it takes a restart of HS to get that going?
    Marty
    XPpro SP3 /w HS Standard 2.5.0.80, HSTouch Server - 1.0.0.70, HSTouch Client 1.0.0.73 HSTouch Android - 1.0.0.2, HSTouch iPhone - 1.0.0.2
    Playing with HS3 a bit but it's just play at this point.
      Never mind... Error between the ears....
      I found out what shows up there... it's the entire text of the line in the log that triggered the event.
      I found it out as I was trying to find out why I couldn't get BLLogmonitor to work at all. I hadn't put the entire path to my Homeseer log file (ah.log) in the setup, so it wasn't seeing the message show up in the log. Once I got that set up properly then my event triggered properly and my V34 devicestring was filled with the line in the log that had triggered the event. Ta Da!!
      Dick
        I have the same question, but I can't figure out what Ram is explaining. What is the purpose of the box labeled "Device Code to store log file data: "?
        HS3Pro on Windows 10
        One install with 2 Ethernet Z-nets
        2nd install with 1 Zstick
        300 devices, 250 events, 8 scripts
        5 CT-100 tstats
        Serial IT-100 interface to DSC Panel with 8 wired zones
        18 Fortrezz water sensors & two valve controls
        Serial Rain8Net Pro with 8 zones
