HS3 logs not plain text
  • #16
    Anyone know if there is a linux port of the LOG2TEXT utility? When initialized on linux, it gives a couple errors about directories not existing.
    • #17
      I too need a Linux version since it writes to directories with the wrong direction \. That writes the file correctly originally but then it cannot write to it again (or read) since in order to create a \ (which is just an escape character on Linux) it requires two \\ to get to the file name. Hence that's why it cannot read the files.
      Any chance you can fix this so it will write to the right directories in Linux?
      Thank you.
      Rich Vonisnki
      • #18
        Linux version available.
        I don't run Linux so can't test.
        • #19
          I started to use LOG2SYSLOG today but it started to crash. Wil there be a new version soon to fix this
