Aeotec MultiSensor 6 Problem
    I have installed 2 Aotec Multisensor 6 units, which included perfectly, but BL RAdar is not triggering, apart from updating the date/time, when the device or sensor changes to movement detected. The value of the device does change from 0 to 255, but shows vacant.
    sigpic
    A founder member of "The HA Pioneer Group" otherwise known as the "Old farts club!"
    HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
    BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
    BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
    Did you set them up in BLRadar and value triggered and enter in the off and on values?
    Cheers,
    Bob
      They are set up in BLRadar but did not enter the on and off values, will do that now
      sigpic
        Made no difference, however here is an excerpt from the debug log when one of them triggered
        01/03/2017 13:38:50 : v2.0.126.0 - HomeseerFunctions.TriggerSensorChange():         **** sensor DOES NOT MATCH!
        01/03/2017 13:38:50 : v2.0.126.0 - HomeseerFunctions.TriggerSensorChange(): * processing trigger (evref: 268;TANumber: 1;SubTANumber: -1;UID: 3711)
        01/03/2017 13:38:50 : v2.0.126.0 - HomeseerFunctions.TriggerSensorChange(): Trig.Result --> True
        01/03/2017 13:38:50 : v2.0.126.0 - HomeseerFunctions.TriggerSensorChange(): Trig.WhichTrigger --> SensorChange
        01/03/2017 13:38:50 : v2.0.126.0 - HomeseerFunctions.TriggerSensorChange():     Trig1 --> 752 (TriggerType: Echo; TriggerUID: 3711)
        01/03/2017 13:38:50 : v2.0.126.0 - HomeseerFunctions.TriggerSensorChange():         Trig1.ToString -->
        TriggerSensorChange:
           TriggerUID: 3711
           SensorKey: 752
           TriggerType: Echo
        sigpic
          Delete the debug log, then turn it on again and capture one triggering, then turn off debug logging and attach it here zipped
          Cheers,
          Bob
            Here goes.
            sigpic
              Which device code or ref is it?
              Is the ref 752?
              Cheers,
              Bob
                I see the event being triggered:
                Does the event have any other conditions on it?
                01/03/2017 14:58:43 : v2.0.126.0 - HomeseerFunctions.TriggerSensorChange(): Trig.WhichTrigger --> SensorChange
                01/03/2017 14:58:43 : v2.0.126.0 - HomeseerFunctions.TriggerSensorChange(): Trig1 --> 752 (TriggerType: Echo; TriggerUID: 3711)
                01/03/2017 14:58:43 : v2.0.126.0 - HomeseerFunctions.TriggerSensorChange(): Trig1.ToString -->
                TriggerUID: 3711
                SensorKey: 752
                TriggerType: Echo
                01/03/2017 14:58:43 : v2.0.126.0 - HomeseerFunctions.TriggerSensorChange(): ** sensor MATCHES!
                01/03/2017 14:58:43 : v2.0.126.0 - HomeseerFunctions.TriggerSensorChange(): TRIGGER TYPE MATCHED!!!!
                01/03/2017 14:58:43 : v2.0.126.0 - HomeseerFunctions.TriggerSensorChange(): Trigger was EXECUTED!!!
                01/03/2017 14:58:43 : v2.0.126.0 - HomeseerFunctions.TriggerSensorChange(): * processing trigger (evref: 2768;TANumber: 1;SubTANumber: -1;UID: 3633)
                01/03/2017 14:58:43 : v2.0.126.0 - HomeseerFunctions.TriggerSensorChange(): Trig.Result --> True
                Cheers,
                Bob
                  TriggerUID: 3711
                  SensorKey: 752
                  TriggerType: Echo
                  Thanks, yes since I entered the on and off values both devices have eventuatly started working as they should.
                  sigpic
