No sensors or active zones have been assigned to BLRadar
  • No sensors or active zones have been assigned to BLRadar
    All my sensors and active zones disappeared from the BLRadar webpage. I can still see them under Homeseer device list.
    Obviously, all my motion sensors and active zones events stop working.
    Any idea on what is wrong? I am using HS3 and latest version of BLRadar (2.0.126.0).
    Marcus
    Can you send me your hspi_BLRadar.ini file zipped
    Cheers,
    Bob
      Here you go. Thanks!
        Wow that is strange that are all gone
        The plugin does create a backup or you can go to one of your backups to get it back
        I am going to look at the code now to see if I can see where that might happen
        Cheers,
        Bob
          Did you notice it happen on a shutdown of the plugin?
          Cheers,
          Bob
            I have posted 2.0.127 to the HS3 updater
            I am not positive that it will not happen again so please keep a backup
            Let me know if you see it happen again
            Cheers,
            Bob
              That happened after an upgrade. Any idea how to restore? I can still see my devices under the device list.
                Try out 2.0.127 I posted to updater
                I am wondering if the writing to the INI file got corrupted on the shutdown. I have never seen this on my end but if you see it again let me know
                Cheers,
                Bob
                  this has just happened to me also, everything has broken. trying to get it from backup now.
                    Are you using 2.0.127?
                    If so I will need to investigate this some more
                    Cheers,
                    Bob
                      This has happened now for the third time in the last 4 months or so, did you have any luck resolving?
                        No luck - I have not been able to reproduce it which makes it hard to fix.
                        When it happens do you lose the entire INI file?
                        Cheers,
                        Bob
                          Same here. All gone.
                            Motion Sensors not working
                            Updated from .126 to .127 today. None of the motion sensors are reacting to motion. Devices still show on BLRadar web page and in HomeSeer devices.
                            The install failed the first time, but appeared to work on the second try. Have disabled the plugin and re-enabled without success. SHould I un-install and re-install?
                            EDIT: another disable and enable cycle has restored their function.
                              When you see this happen are you doing any updates in the plugin?
                              Does it happen on a restart of the plugin?
                              Cheers,
                              Bob
