Aeon Labs Multisensor 6
    I have a few Aeon Labs Multisensor 6 units, and cannot get them to work with BLRader. I can set them up as a motion sensor and they do trigger, however the associated occupancy sensor does not trigger????
    HomeSeer 3 V 3.0.0.318 with ALEXA (AKA Amazon Echo)
    BL Radar V2.0.217; BLRF V2.0.85.0; HS Touch V3.0.0.1034 X10 V3.0.0.42; PHLocation V3.0.0.38; Zwave V3.0.1.110; X10 V3.0.0.42
    BLBackup V2.0.39;ImperiHome3.0.0.20 All on Windows XP Pro
    Did you set them up as a value triggered device? You may need to go the device status graphic pairs to get the values
    Cheers,
    Bob
      Yes they are set as value triggered.
        Capture a debug log of one triggering and let me know the device reference so I can trace it though
        Cheers,
        Bob
          Hi Bob, sorry you are going to love this. Read in another post that parameter 4 should be set to 5 prior to my original post above. In HS that will show as motion disabled, but in fact it is.
          When I triggered it to create the debug log it worked perfectly, I'll keep an eye on it for the next few days.
          Sorry to have taken up your time.
            No problem - glad you got them working
            Cheers,
            Bob
              Multisensor 6 with Homeseer zwave plugin
              I've been messing with two of these sensors for several days and cannot seem to get them to work reliably. In particular I need some insight into the tampering function. Every time I touch the sensor it sets off the "cover removed/Tampering" event. That takes several minutes to recover but then it goes into the "Unknown" state -- value=254 and seems to sit there indefinitely If I reset the sensor it might work for a while but if I bump it (or just try to install it on it's mount) it goes right back to the tampering issue. Has anyone else had this issue? I've tried firmware 1.07 and 1.08, same results. Thanks in advance.
