Errors on Startup since updating to BLRadar 2.0.130
  • Errors on Startup since updating to BLRadar 2.0.130
    Ever since I upgraded to the latest release of BLRadar I started getting these errors on HS3 Pro startup.
    Nov-14 17:12:03 BLRadar start BLRadar version is: 2.0.130.0
    Nov-14 17:12:03 Error In ReadINI:Item has already been added. Key in dictionary: 'sensor=94' Key being added: 'sensor=94'
    I get 225 of these error messages and then the rest of the startup completes. I have not seen any other errors. If I disable BLRadar before shuting down I do not get the errors on startup or when I enable BLRadar after startup.
    Any ideas????
    Current Date/Time: 11/14/2017 17:54:12
    HomeSeer Version: HS3 Pro Edition 3.0.0.357
    Operating System: Microsoft Windows 7 Professional - Work Station
    System Uptime: 0 Days 0 Hours 42 Minutes 57 Seconds
    IP Address: 192.168.
    Number of Devices: 628
    Number of Events: 278
    Available Threads: 400
    Enabled Plug-Ins
    2.0.22.0: BL1Wire
    2.0.59.0: BLDSC
    2.0.32.0: BLNetCallerId
    2.0.130.0: BLRadar
    3.1.1.24385: Blue-Iris
    2.0.22.0: BLUPS
    2.0.10.0: BLUSBUIRT
    1.0.0.5: Restart
    3.0.6440.19101: UltraMon3
    3.0.6524.19944: UltraWeatherWU3
    3.0.0.36: X10
    3.0.1.130: Z-Wave
    I will have a look at your log
    The change I made should not have caused that
    Can you also attach your hspi_BLRadar.ini file zipped
    Cheers,
    Bob
      The attached file is the .ini file renamed to .txt. I will attach the log file this evening when I return home. Where is that file located at?
      Thanks for your help
        The debug log is in the HS3 root folder
        Did you change your HS3 version as well
        I know there was an issue with a HS3 version and INI processing
        What version of HS3 are you running
        Cheers,
        Bob
          No I did not update my HS3 Pro at the same time. I am still on .357 and have not upgraded to HS3's latest.
          Here is the detailed debug log
            Can you try 2.0.131 and see if you see those errors.
            I looked in the code and I could not see where I was outputting an error like that
            Cheers,
            Bob
              I will give that a try this afternoon
                No errors on startup with 2.0.131
