Seeing Delays with newer Homeseer Betas
  • MrMxyzptlk
    I trying this know, will let you know how it goes.
  • cerjzc
    Just as an update. I noticed in another thread for Imperihome they were seeing similar issues so I reported this issue there and Spud was able to speak to Rich about it.
    They have updated a new build .396 that is supposed to remove some of the queuing that most likely was causing the delays and missed value changes.
    I installed it before going to work and it seemed fine before I left, but only had limited experience with it before I left.
    If you would like to try it the link is here:
    https://forums.homeseer.com/showpost...9&postcount=47
    Jeff
  • MrMxyzptlk
    Me too, as well as 'ghosting' issues where I turn off zwave lights and they suddenly come back on.
    I'm on .391
  • ScottRennie
    Me too - it is driving me nuts!
  • peterpc
    I see the same problem. Lights go on sometimes more then 10 seconds after triggering.
    In one room I have a squeezebox, that is playing right away, but lights (Insteon) go on 10 seconds or more later on the same motion trigger.
  • cerjzc
    started a topic Seeing Delays with newer Homeseer Betas
    I have noticed over the last 3 or so weeks that I have been getting a number of delays or completely missed triggers, but hadn't been able to track down exactly what was responsible. I had updated HS, Zwave and Blradar all close to the same time so I started with moving back to an older version of Blradar, but the problems continued. Last night I had a chance when everyone was asleep to turn on debugging and watch the logs a bit and what I'm seeing is a 10 to 20 second delay between the sensor triggering and the code being run in BLRadar.
    Dec-11 12:10:22 AM Z-Wave Device: Node 6 Basement Fridge (Light) Set to 255
    Dec-11 12:10:22 AM Device Control Device: Node 6 Basement Fridge (Light) to On (255) by/from: CAPI Control Handler
    Dec-11 12:10:12 AM Z-Wave Device: Node 4 Basement Motion Sensor Set to On/Open/Motion
    (10 second delay turning on light from UDMC code for that motion sensor)
    In that example the device triggered at 12:10:12 and didn't run the code in BLRadar until 12:10:22 -- so 10 seconds later. So I checked the debug log and sure enough it doesn't appear that BLRadar. So I checked the BLRadar debug log and it appears to confirm that it didn't receive the value change until 12:10:22
    12/11/2017 12:10:22 AM : v2.0.127.0 - HSEvent(): EventType --> VALUE_CHANGE
    12/11/2017 12:10:22 AM : v2.0.127.0 - HSEvent(): ref --> 2248
    12/11/2017 12:10:22 AM : v2.0.127.0 - HSEvent(): doProcess --> True
    12/11/2017 12:10:22 AM : v2.0.127.0 - DeviceReceivedQueueSingleton.AddDeviceReceivedToQueue() started
    12/11/2017 12:10:22 AM : v2.0.127.0 - DeviceReceivedQueueSingleton.AddDeviceReceivedToQueue(): theDeviceReceivedData.ToString -->
    DeviceReceivedData:
    EventType: VALUE_CHANGE
    parms(1): 1024
    parms(2): 003D21D1-004-Q226
    parms(3): 255
    parms(4): 0
    parms(5): 2248
    So in that case it doesn't appear BLRadar is slow just that it didn't receive the update from HS until that later time. I checked several other examples and they all appeared to confirm the same experience. And sometimes the device never triggers the on or off and in the case of the off being missed the Sensor Recovery will finally kick in.
    Another example of it turning off and a 19 second delay:
    Dec-11 12:14:43 AM Z-Wave Device: Node 6 Basement Fridge (Light) Set to 0
    Dec-11 12:14:43 AM NO ECHO No Echo for Basement Motion Sensor, Echo (1 mins, 39 secs)
    Dec-11 12:14:43 AM Device Control Device: Node 6 Basement Fridge (Light) to Off (0) by/from: CAPI Control Handler
    Dec-11 12:14:24 AM Z-Wave Device: Node 4 Basement Motion Sensor Set to Off/Closed/No Motion
    The value change from 12:14:43 instead of 12:14:24 when BLRadar should have received it:
    12/11/2017 12:14:43 AM : v2.0.127.0 - HSEvent(): EventType --> VALUE_CHANGE
    12/11/2017 12:14:43 AM : v2.0.127.0 - HSEvent(): ref --> 2248
    12/11/2017 12:14:43 AM : v2.0.127.0 - HSEvent(): doProcess --> True
    12/11/2017 12:14:43 AM : v2.0.127.0 - DeviceReceivedQueueSingleton.AddDeviceReceivedToQueue() started
    12/11/2017 12:14:43 AM : v2.0.127.0 - DeviceReceivedQueueSingleton.AddDeviceReceivedToQueue(): theDeviceReceivedData.ToString -->
    DeviceReceivedData:
    parms(1): 1024
    parms(3): 0
    parms(4): 255
    parms(5): 2248
    I decided to try to downgrade from the current HS beta which is .393 and found a version of .379 I had saved and put in the files for it and restarted.
    As of now I haven't noticed another delay although I'm still monitoring. Has anyone else noticed this with the newer HS betas? I'm not exactly sure which one the delay was first noticed in, but I think it was in the mid 380's as I know Rich has been working with some of how the queues for the plugins are processed so it is quite possible that one of those changes might be effecting this.
    I might need Bob to help confirm this and explain how he receives those values from HS so that Rich can review this further as the last several version of HS have been fairly unreliable with BLRadar because of this.
    Jeff
