Virtual Device No Longer Controllable Once In BLRadar
  • Virtual Device No Longer Controllable Once In BLRadar
    There is a problem with my new setup with BLRadar. I made a video to show you all the details of what is going on.
    I create a simple virtual device and I can of course turn it on or off. But when this same virtual device is added as a motion sensor in BLRadar all control of the device by ANY mechanism is gone until it is deleted from BLRadar. WHY? This used to work.
    See simple video to see what I am talking about.
    Jean-Marie G. Vaneskahian
    jean@vaneskahian.com
    I will have a look at your ticket you logged and let you know
    Cheers,
    Bob
      Thank you Blade, I appreciate it very much.
        Same test as before, but now using values in BLRadar (I forgot that I has tested this before I posted as well). Does not make a difference at all. I have tried everything I could think ok. I have never seen this behavior in BLRadar previously.
        Here is a video of me using the values in BLRadar and looking at the logs. The logs register the change, but the value does NOT change.
          Can anyone else try to duplicate this? When you create a virtual device in HomeSeer and it is controllable, does it lose the ability to be controlled once added to BLRadar (as is shown in the video)? Does anyone else see this?
            Pardon the question, in what circumstances do you use virtual devices in Blradar ?
            Hector
            Win.2003 OS, HS3
            MyTrigger,ACRF2,W800,Zwave
            AP800,Honeywell Stat
              Example, when you create a Active Zone, I use a virtual device. I also create a virtual device when I want to have a door call the virtual device so that when the door is open it acts as a Motion Sensor and then times out after say one minute. The door open can then trigger turning on lights and the door close can do the same and in BLRadar the virtual device is setup as a motion sensor... this used to all work great before.
                Should be fixed in 2.0.135
                Cheers,
                Bob
