BLRadar 2.0.138 and above
This is a sticky topic.
  • BLRadar 2.0.138 and above
    BLRadar 2.0.138 and above introduces a change to the settings file used by the plugin
    It will convert your hspi_BLRadar.ini file to a BLRadar.xml file
    It will rename your INI file so you have it as a backup
    Hopefully this will help with the settings getting wiped out
    It is in the beta section in the updater
    Let me know if any issues
    Cheers,
    Bob
    Bob,
    I upgraded to .138 tonight. I have an XML file and the .ini.bak. I only have 2 devices out of 27 after the update. I shut down .138, deleted the XML file, renamed a copy of .ini.bak to .ini and restarted .138. Same 2 sensors again in the XML file.
    Now what?
    Dale
      Bob,
      I painlessly restored to .137 this morning and all is well. Let me know if there is anything I can do to help troubleshoot with .138 should others be having the same issue I had.
      Dale
        Not that it will help, but I did upgrade to .138 back on the 25th and it went without issue and all of my devices appear to still be there.
        Are the 2 devices that do get copied maybe the first or last ones in the file?
        Jeff
          Originally posted by dale View Post
          Bob,
          Dale
          Post your hspi_BLRadar.ini file zipped
          Cheers,
          Bob
            Bob,
            Here is the ini and xml zip files. I hope they help.
            Dale
              Disable BLRadar
              Delete the BLRadar.xml file and rename your INI back to hspi_BLRadar.ini
              Then edit the hspi_BLRadar.ini file and change the following:
              [sensor=
              to this:
              [Sensor=
              There are lowercase sensor= in the file and they should be Sensor=
              Once you have made all replacements in the INI file, then save it and restart the plugin again
              Cheers,
              Bob
                Disable BLRadar
                [sensor=
                to this:
                [Sensor=
                Bob,
                That worked without a hitch. I'm guessing that INI file was back from HS2 since I haven't really done anything with it since then. It all just works. And it works again under .138.
                  Glad it worked
                  Cheers,
                  Bob
                    Thanks for the help and quick response.
                    Dale
                      Blade, I installed 138 and I lost half of my devices!!! How can I recover them back??? I can see the devices on the device page, but if I go to the Blradar page I only have a few of them.
                      Hector
                      Win.2003 OS, HS3
                      MyTrigger,ACRF2,W800,Zwave
                      AP800,Honeywell Stat
                        Rename the hspi_BLRadar.ini_OLD back to hspi_BLRadar.ini
                        You will also have to go back to the previous version of the plugin
                        Attach your hspi_BLRadar.ini zipped
                        I would like to see why it is happening
                        Cheers,
                        Bob
                          How do I return to the previous ver?
                          Hector
                          Win.2003 OS, HS3
                            here the file...
                            Hector
                            Win.2003 OS, HS3
                              Bob,
                              Dale
                              How did you go back to 137?
                              Hector
                              Win.2003 OS, HS3
